Changing Volvo 290 DP lower unit lube
Volvo Penta
Old 06-06-2010, 01:34 AM   #1
c6timmons's Avatar
c6timmons is currently offline
My Model: 240 Z
My Engine: Volvo 572 w/290 DP
Send c6timmons:
Default Changing Volvo 290 DP lower unit lube
I purchased a 1993 240Z with a Volvo 290 DP last year. I ran the boat about 55 hours in 2009. Lower unit lube was checked at time of winterizing and was free from water but seemed rather used (dark and smelly). I have run the boat 5 hours this season before changing the lower unit lube. I changed the lower unit lube yesterday. I used Volvo GL5 80/90 weight lower unit lube as specified in my operators manual. The Volvo product has the appearance of motor oil. I took the boat for a test drive and returned home. While cleaning the boat I noticed lower unit lube leaking from around the prop shaft housing and down the skag. I removed the bottom plug to get a better look and the lube seemed almost milky "lima bean" green in color. Does this mean I am now getting water into the lower unit? Is there a prop shaft seal that needs replaced? Any help is appreciated. Thanks!
  • Old 06-08-2010, 04:31 PM   #2
    c6timmons's Avatar
    My Model: 240 Z
    Send c6timmons:
    Default Re: Changing Volvo 290 DP lower unit lube
    I thought I would update my post based on what I have done so far. I drained the fresh Volvo lower unit lube and there did not appear to be any water mixed in with the gear lube. Again the color of the lube seemed to be a little off. I did not have access to Volvo lube on a Sunday so I purchased Mobil 1 Synthetic 75-90W lube. I refilled the lower unit and started the engine with the water muff on the lower unit in the drive way and ran the engine in gear for a couple of minutes. There was a slight leak of lube down the skag coming from between the anode and the prop shaft housing after running. The fluid level was full. I took the boat out on Sunday afternoon and everything was running fine. There is no evidence of any leaking fluid at this point. There is no evidence of any water in the fluid and the fluid level still reads full. I will keep an eye on it, but everything seems ok at this point. Thanks!
    290 dp , lower unit lube , volvo , water
    Lower Unit will not engage All In Original Mariah Talk 5 11-04-2009 04:52 PM
    need help changing gear lube on alpha one outdrive. pimpadelic General Maintenance 9 07-01-2009 05:41 PM
    Lower unit switch? Z212NH Original Mariah Talk 5 05-31-2009 12:03 PM
    Lower Unit Drain Plugs Buffalo_Bill Volvo Penta 0 05-10-2009 02:22 PM
    i/o lower unit gear oil bryce6horse Mercury MerCruiser 1 04-25-2008 03:53 PM
    There are 253 users
