Need help with trailer tires
Trailering and Tow Vehicles
Old 09-11-2013, 03:57 AM   #11
Shane.walker11's Avatar
Shane.walker11 is currently offline
My Model: 202
My Engine: 5.0
Send Shane.walker11:
Default Need help with trailer tires
I would go to the local tire shop and ask for the highest ply tire they have for that size. Thats alot of weight and it likes to sway. I had to upgrade the tires on the truck b/c i tow a cab over camper and my boat and i was getting alot of sway and blew out a couple tires till i switched to a higher ply tire.
  • Old 09-11-2013, 04:51 AM   #12
    Default Re: Need help with trailer tires
    That is the problem , they don't have higher rated tires in the 14" size he has. Everything is load range C anymore.
    Old 09-11-2013, 08:48 AM   #13
    My Model: 202
    My Engine: 5.0
    Well i guess you could always put wings on it and fly it wherever you need to go!! j/k hahahaha
    Old 09-11-2013, 02:23 PM   #14
    luke7575 is currently offline
    My Model: z302 Shaba
    My Engine: 7.4l Volvo Penta Duop
    Send luke7575:
    Hahaha very funny i wish i could.
    Oh and im located in Houston Tx
    Old 09-11-2013, 03:01 PM   #15
    95gts's Avatar
    95gts is currently offline
    My Model: Shabah 182
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    I found some nice Kumho load range D 14" tires last year.. They're very well made.
    http://www.tirerack.com/tires/tires....del=Radial+857
    Old 09-11-2013, 04:18 PM   #16
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    Thanks for the info for ST tires I usually keep mine at 35. Bumped up to 45psi now.
    Patrick
    Old 09-11-2013, 08:44 PM   #17
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    I pulled my 302 from Tulsa to KC to Lawrence to LOTO running 70-75 with no problems. Two new tires on 1 out of 3 axles.
    Old 09-12-2013, 07:07 AM   #18
    http://m.discounttire.com/dtcs/findT...=COPINT&cs=205
    I bought the boat with 4 brand new tires like this on its trailer. They seem to be holding up well. I had no idea about ST being sub par to the LT tires. Not that I plan on buy buying anytime soon but I'll have to look into that for the next go around
    Old 09-15-2013, 08:00 PM   #19
    Send luke7575:
    Those are the same tires im running
    Old 02-24-2014, 06:20 AM   #20
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    I'd like to 2nd the recommendation for the Kumho tires. I've had a set on the boat trailer for 3 years now with no issues. They're made in Korea and not China.
    Check your trailer tires!!!!!!!! StudpuppyandTitesqueeze Original Mariah Talk 4 06-19-2013 02:50 AM
    Spare tires rayzorback Original Mariah Talk 5 03-11-2012 05:24 AM
    Khumo trailer tires m&mmariah Trailering and Tow Vehicles 6 11-28-2010 03:53 AM
    Need new trailer tires John Miller Trailering and Tow Vehicles 2 04-22-2009 02:09 AM
    Trailer Tires 300sflyer Trailering and Tow Vehicles 6 06-29-2008 02:49 PM
    There are 317 users
