Can't get the daggone boat to load up correctly! GRRRR
Trailering and Tow Vehicles
Old 07-31-2009, 08:45 PM   #11
pimpadelic's Avatar
pimpadelic is currently offline
My Model: 1996 180 shabah 3.0L Alpha I Gen II
Gallery Images: 7
Send pimpadelic:
Default Re: Can't get the daggone boat to load up correctly! GRRRR
Originally Posted by blockp View Post
When your truck is that deep, how far under water are the fenders of your trailer?
If you're feeling adventurous sometime, try just barely covering the fenders and see how your boat loads. You may find you can load your boat quite easily with the added bonus that your feet don't even get wet.
my fenders are about a foot under the water.
if i dont put it in that much i have the same problem as the OP and i cant pull boat all the way on the trailer. and with these custom trailers if u dont pull the boat all the way on my lowwer unit hangs too low for comfort.
  • Old 07-31-2009, 08:46 PM   #12
    pimpadelic's Avatar
    Gallery Images: 7
    Send pimpadelic:
    Smile Re: Can't get the daggone boat to load up correctly! GRRRR
    i dont mind getting my feet wet. i am in a boat at the lake. i kinda plan on getting alittle wet.
    Old 07-31-2009, 10:45 PM   #13
    otisroy's Avatar
    otisroy is currently offline
    My Model: 182 Shabah
    My Engine: 4.3L Alpha One
    Send otisroy:
    Not sure about the newer trailers, but with the older Prestige trailers, dipping them until the tops are fenders are at the water line is about perfect whether we're at the launch or just revovering straight off the beach. Same goes for my jet ski trailer too. The older Prestige trailers are really low so, as stated before, you have to be careful with your drive or in my case the trailer acting like a sled in deep sand.
    Old 08-02-2009, 03:09 PM   #14
    LluberesMM is currently offline
    Send LluberesMM:
    Thanks to all of your comments. Yesterday, we sunk the trailer fenders till they were just under water, as many of you suggested, and I was able to drive the boat right up the trailer perfectly! Finally, I did something right!!
    How to Load a Bayliner into a Pickup 101. z275st Chit Chat/Off-Topic 5 01-12-2009 01:29 PM
    alpha 1 load ratings lawmanbsi Original Mariah Talk 1 08-31-2007 06:15 PM
    There are 315 users
