Towing Capacity Question
Trailering and Tow Vehicles
Old 08-20-2010, 02:15 PM   #21
candanewell is currently offline
My Model: 202
Default Re: Towing Capacity Question
Hi All,
Similar question but for a 202 shabah......boat comes in at 2800lbs, but sure what the trailered weight would be?
currently I have a 5.4 V8 Isuzu Acender with 6400lbs but looking at newer cars I may have to go down to a V6 with 4500lbs.......
  • Old 08-20-2010, 08:58 PM   #22
    WalkinOnWater is currently offline
    Status: Silver Contributor
    My Model: Z-202 Shabah Ltd
    My Engine: 5.0L EFI Alpha
    I had this concern recently. I sold my Durango last year, so when I bought my Z202 I was wondering if my wife's 2008 Ford Explorer Sport Trac would pull it. The truck itself is very solid and has a longer wheelbase than the SUV Explorer, but she only has the 4.0L V6...and the 3500LB hitch. After discussing it with a boater friend he assured me it would be no problem. He has a 2006 Sea Ray 200 Select and for the first summer he pulled it with a Chevy Equinox. I decided I would try pulling it with our Sport Trac and if it was uneasy, then I would go buy myself a truck.
    After pulling it for the summer (including two 500-mile round-trips), I am at ease. Believe it or not, my buddy was right. This truck doesn't even think about it. Even though it's a V6, it's 210HP is the same as the brand new GMC Z-71 I bought back in 1994 with a 350 V8 in it. The braking is just fine also - no problem. (my trailer has tandem axle and surge brakes so that helps I'm sure)
    I'm not comparing it to that 1/2 ton pickup. I know there are other factors - frame, suspension, torque rating @ rpm, and yes the biggy - transmission, but if you are careful driving it can be done. My only big issue is the hitch itself. Dang Ford! I still plan to buy myself another truck soon and then I'll pull it with that, but for now the Sport Trac gets the nod.
    I know you are considering other vehicles (not Sport-Trac) but the issues are similar and I would suggest you buy as much vehicle as you can live with (and pay for) if you are towing. But if you need a smaller for the majority of your driving and just occasionally pull your boat, it can be done.
    Old 08-21-2010, 01:37 PM   #23
    My Model: 202
    thank you that is reassuring ..... I guess i would not have the question if i had a smaller vehicle first as the boat and trailer weight is within the rated towing capacity.....
    Gas Tank Capacity steve Original Mariah Talk 9 06-26-2009 01:05 AM
    what are you towing??? mashymariah Watersports 6 02-07-2009 10:41 PM
    What's my capacity after overbore? DGR-Z246-98 Original Mariah Talk 9 12-14-2008 01:26 PM
    fuel capacity cole Introductions 2 08-15-2008 03:36 PM
    fuel tank capacity jchemotti Mercury MerCruiser 9 07-04-2008 05:41 AM
    Total Members: 6,945
    Total Threads: 6,287
    There are 35 users
