Taillight lense replacement.
I need to replace the lense on the trailer taillight and the orange courtesy light. Trailer is 1997 Chariot for Shabah 180se. Is this something I can get at Auto Zone?
Re: Taillight lense replacement.
Possibly yes. Or try places like West Marine.
UPDATE: Got new LED lights.. discovered that of the 3 slots in the back of the light, two of them line up just right with my existing bolt holes. During my research I found out you must be very careful when potting the bolts in the slots. Push to hard and the plastic of the slot will break and then you have even more issues.. cannot wait to see all those LEDs lit up…should be super bright. Get them installed tomorrow.
I have a 1997 Shabah 198 SE with the Chariot trailer it came with. The right side taillight is not working.. I want to replace both lights with LED’s. Everything I have found has slots on the back for 3 bolts to attach to the trailer. My existing assembly has 2 bolts that are part of the light box itself. Slide them thru the 2 holes on the trailer and you are good to go.. My question is where can I find new LED lights with the bolts attached to fit my trailer. Been hunting everywhere and having no luck. |
| All times are GMT. The time now is 06:53 AM. |
