-   Sea Fox - Mariah Talk (http://www.mariahownersclub.com/forum/sea-fox-mariah-talk/)
-   -   Buying Advice - SX25 (http://www.mariahownersclub.com/forum/sea-fox-mariah-talk/7779-buying-advice-sx25.html)
Booberry 02-08-2013 02:19 AM
Too big can be a problem. I am facing it now. I want to buy a Mariah 25SX and will have to trailer it to storage after each use. Also, will have to trailer it 6 hours to Key West. I am not sure but I think my Lincoln Navigator has the towing right on the borderline for that boat.
I started off looking for boats in teh 20-21 foot range and here I am about to get a 25. What happened here?
ShabahZ280 02-08-2013 03:56 PM
Re: Buying Advice - SX25
Your Navigator should be able to handle towing a SX25. The SX25 weighs only about 4,000lbs. Add the weight of the trailer (steel trailer that size, maybe ~1700lbs, aluminum trailer, maybe ~1200lbs). That'll put you in the neighborhood of 5200-5700lbs. You're still under the 8600lbs towing capacity of the Navigator.
Shane.walker11 02-09-2013 12:25 AM
What i did even though i didnt even really nedd them was, i went to the tire shop and had airbags installed and when i tow stuff, i air them up to 80psi. They were 750$ installed and i have been happy ever sense.
smokey9015 02-09-2013 12:54 AM
Depending on the year the navigator should already have a OEM self leveling air ride installed already.
Sent from my DROID RAZR using Tapatalk 2
Motoxxx43 02-09-2013 08:29 PM
It will tow good down there. I just picked up a 4400lb (I think) 25' boat with my F150 and towed it 860 miles home. The hardest part of the drive would be the hills and head wind. I managed to average 8-9 MPG.
