Salt Water Running
Sea Fox - Mariah Talk
Old 04-28-2011, 05:32 PM   #1
Y-Knot's Avatar
Y-Knot is currently offline
My Model: 2009 FS-18 4.3 Mercruiser Alpha I
Send Y-Knot:
Default Salt Water Running
Hi All,
We run our FS18 in fresh water but see a day when we might trailer to the Florida coast for vacation.
Is there anything I need to do with the power unit other than flush well before returning home? Are there special salt water "options" for Mercury power units running in salt water?
Cheers,
Y
2009 FS-18, 4.3 Alpha 1
  • Old 04-28-2011, 07:47 PM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Salt Water Running
    We boat quite a bit in the salt water and I would always have a fresh water cooling system on a boat I used in salt water. This is a closed cooling system that circulates coolant through the engine and only allows the sea water to be pumped from the outdrive through the heat exchanger and discharge through the exhaust.
    I just finished installing one one mine, and it ran about 1000 bucks by the time I was done.
    Some say dont bother since the life expectancy on the block isnt worth the cost and hassle, but I disagree and would preffer to keep it as good as possible and as long as possible.
    One more note though, flush the system with fresh water hose and run through outdrive muffs after pulling the boat out of salt water every time. This will reduce any negetive effect from the salt water.
    And make sure your zinc's are in good shape since they are the sacrificial anode to keep the outdrive from being attacked.
    Zack
    1994 Z212 Shabah
    Thank you Zackattack for this useful post!
    mikeyt (04-28-2011)
    running with a water hose/ear muffs midwest mariah Original Mariah Talk 17 06-13-2011 02:44 PM
    Bubbly salt(?) deposit RichB Original Mariah Talk 12 04-06-2011 09:38 PM
    Help 454 Running bad??? karmann Original Mariah Talk 2 08-13-2010 10:49 PM
    Salt Water Earthing DGR-Z246-98 Original Mariah Talk 1 12-28-2009 02:28 AM
    Running very bad need help mike2828 Original Mariah Talk 1 11-19-2009 04:32 AM
    There are 433 users
