Need some help please
Sea Fox - Mariah Talk
Old 03-22-2010, 11:22 PM   #1
jdecoudres's Avatar
jdecoudres is currently offline
My Year: 2008
My Model: sx20
My Engine: 5.0 alpha 1
Send jdecoudres:
Default Need some help please
Im not sure where the fuse panel is or where the fuse is so need some help from u guys please. I hooked up my battery in my boat today. Everything works radio,blower lights,horn all that but no power at the key.. When u turn the key on u get that loud Beep noise right before u start it and im not getting that and no power at the key. Anyone have any ideas. Im pretty sure i hooked the wires up on the battery right as this is the first winter i removed battery. 2008 sx 20
  • Old 03-23-2010, 01:42 AM   #2
    Default Re: Need some help please
    I'll have to leave this to one of the guys who have a new Mariah. Mine is located behind the dash with access from underneath. Check to make sure you got the small wires attached to the battery also cuz they can be easily overlooked. Also check the back of the ignition switch to ensure all wires are firmly attached. Also, is your "Run/Off" switch (safety switch) set to Run?
    Old 03-23-2010, 01:58 AM   #3
    jdecoudres's Avatar
    My Year: 2008
    My Model: sx20
    Send jdecoudres:
    Thank You for your help I got it fixed, There was a 50 amp circut on top the motor i pushed it in but apperentley when it pops out it pushes a little level on the bottom so i had to push it up and then pusth the circut in. Thanks for all your help.
    There are 224 users
