Manually Raise Outdrive?
Sea Fox - Mariah Talk
Old 04-04-2009, 02:50 AM   #1
stevorat's Avatar
stevorat is currently offline
My Model: 2003 Mariah SC19 w/Mercruiser 190 V6 Alpha 1
Send stevorat:
Default Manually Raise Outdrive?
My trim and trailering switches don't work and the outdrive is down. Any ideas as to how I can raise the outdrive to take the boat to a repair facility?
Steve '03 19SX
Steve
  • Old 04-05-2009, 03:25 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Manually Raise Outdrive?
    You can disconnect the trim rams and then prop/tie it up. That'll work until you get to a repair facility. Just pop the caps off where the rams connect to the drive and undo the nuts and bushings on the long shaft going through the housing. Make sure you don't lose any parts. Many marine stores sell a prop that holds the outdrive up you might want to look into picking one up.
    My Mariah
    Trimming Speed for Outdrive Douglas Alderman Original Mariah Talk 1 08-25-2008 05:18 AM
    Refinishing the Outdrive bdbyrnes Projects 2 04-16-2008 05:43 PM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    Poss outdrive problem?? Jeff Barnett Original Mariah Talk 6 09-27-2007 10:02 AM
    Outdrive Play? Jeff Barnett Mercury MerCruiser 2 09-19-2007 07:34 PM
    There are 359 users
