Need info on dash parts for 2350z 1993
Old 08-08-2010, 04:07 PM   #1
erndog123 is currently offline
My Model: 2350z
My Engine: 7.4 bravo
Send erndog123:
Default Need info on dash parts for 2350z 1993
The drivers side dash toggles ( black rubber) over the years have melted/deformed by the sun.
1. Can they be replaced without buying the entire toggle?
2. Do you know where they can be purchased?
3. Do you have a part # or correct name of the part.
Thanks!
  • Old 08-09-2010, 09:14 PM   #2
    Reed Hatch's Avatar
    Reed Hatch is currently offline
    My Model: Z252 Shabah
    My Engine: 7.4L brovo III
    Send Reed Hatch:
    Default Re: Need info on dash parts for 2350z 1993
    My 1996 had the same problem. You can replace just the top part on the switch ( the rocker) They ran about $6.00 apiece and came from a company in North or south carolina. I found the address someplace on this site. If I find it again I will put it on.
    Old 08-09-2010, 10:53 PM   #3
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    See the following: http://www.mariahownersclub.com/foru...-switches.html
    IowaWing
    Steve
    Old 08-23-2010, 01:16 AM   #4
    My Model: 2350z
    Send erndog123:
    Where you able to find the switch info on the supplier. Your support would be greatly appreciated if you could provide you the contact info.
    Old 08-23-2010, 01:44 AM   #5
    Send IowaWing:
    I found this info by typing "rocker switches" into the search box at the top of the page.
    Try here:
    Switches:
    Rocker Switch
    Carling Technologies
    Carling Technologies: Switch & Circuit Breaker Manufacturer
    Available at:
    Custom Marine Services
    Custom Marine Services, Quick Source, Marine Electrical Parts For Boats, Boat Electrical Products, Yachts, Megayachts
    800-992-7922
    They have warehouses in Southern NJ and South Carolina
    IowaWing
    Steve
    engine cover automatic lift rod for a 1993 2350z erndog123 Original Mariah Talk 1 08-05-2010 11:44 AM
    Have some questions about 2350Z brian2350z Original Mariah Talk 1 06-22-2010 06:47 PM
    New 2350Z Owner brian2350z Introductions 3 06-22-2010 01:37 PM
    1993 2350Z prop and outdrive cleah General Maintenance 2 11-21-2008 10:08 PM
    1993, 2350 Z dash instruments cleah Mercury MerCruiser 3 09-09-2008 02:22 AM
    Total Members: 18,994
    Total Threads: 13,326
    There are 506 users
