Question? Courtesty Lights
Old 06-11-2008, 03:00 AM   #1
Gallery Images: 2
Send Douglas Alderman:
Question Question? Courtesty Lights
I'm working on the electrical system. Do the Storage lights - hull storage areas, suppose to come on when using the Courtesy lights - floor & cockpit lighting, dash switch? Or are they separate switches. The electrical schematics doesn't show this.
  • Old 06-11-2008, 06:30 AM   #2
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    Default Lights
    Douglas-
    I have 'transom, eng lights, courtesy (interior cockpit) and a fourth which I don't recall.... sorry its late!
    Brent
    1995 Talari Z240
    7.4L Merc, Bravo III Outdrive
    Corsa Performance Captains Call Exhaust
    Samson Sports Tower
    Old 06-11-2008, 05:38 PM   #3
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    The lights you're referring to are probably under "eng lights".
    Here's a break down:
    Eng Lights - engine and storage compartment below sun deck
    Trans Light - light on the transom (rear) of boat
    Courtesy Lights - interior (floor and cockpit) lights
    Docking Lights - front "headlights" great for docking at night
    Nav/Anchor - self explanatory (at least I hope)
    Don't mean to belittle anyone, just an explanation for those that may have problems (lights burned out, wiring, etc.) and need help locating.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 06-12-2008, 03:18 AM   #4
    Gallery Images: 2
    Question Courtesty Lights
    Do the Storage lights under the seats come on with Courtesy lights?
    Old 06-12-2008, 02:17 PM   #5
    indykoch's Avatar
    Send indykoch:
    Oops! I just noticed you have a Jubilee! I'm not exactly sure what would control those lights.
    Can you put a tester in the socket and turn switches on? Can you trace the wires? I'm thinking you have burned out lights or a bad connection somewhere. I would guess they're on the courtesy or engine compartment switch, but I don't know being a Jubilee. Maybe another Jubilee owner can comment?
    Ryan
    350 Mag MPI
    Old 06-12-2008, 02:38 PM   #6
    from the looks of the 1999 20-24' Deckboat wiring diagram, those lamps appears to be wired into the courtesy lamp circuit. I'd start checking the bulbs!
    Do you have a photo showing where they are located?
    Old 06-12-2008, 04:33 PM   #7
    Gallery Images: 2
    Default Courtesy lights
    Found courtesy switch with loose wire. The storage lights on my boat came on now using engine light switch.
    Replacement Courtesy Lights WetWilly Original Mariah Talk 27 05-24-2020 07:24 PM
    LED Docking lights for your Mariah mikeyt General Maintenance 16 06-18-2010 11:31 PM
    Dash Gauge Lights Out Roger Butterfield General Maintenance 20 01-12-2009 08:38 PM
    dash lights John Miller Original Mariah Talk 3 05-20-2008 02:08 AM
    Wanted: Interior Courtesy Lights? bdbyrnes Mariah Parts For Sale & Wanted 2 10-17-2007 09:48 PM
    Total Members: 18,994
    Total Threads: 13,326
    There are 419 users
