Elevation change on prop selection?
Prop Talk
Old 07-02-2014, 10:19 PM   #11
Default Re: Elevation change on prop selection?
That kinda stuff happens! Its boating! We have logs that come down the river here. They suspend under the surface. I've heard they can take an outdrive clean off.
Glad you weren't injured!
  • Old 07-02-2014, 10:27 PM   #12
    ipgregory's Avatar
    ipgregory is currently offline
    My Model: Z308
    My Engine: Twin 5.0L EFi/Alpha 1s
    Send ipgregory:
    Yup, just one of those things I guess. Was worried I would need a new lower unit but the prop shop guy said he could fix it, we'll see when I get it back.
    Ian
    2000 Z308 MCC, twin 5.0L
    2004 SC21, 4.3L (Sold)
    Old 07-02-2014, 10:46 PM   #13
    Ouch!
    Glad you are OK.
    All I run is Solas Titan SS 4 blade props(19P , 17P , 15P).
    I am very pleased with their performance and quality.
    Shoot us some pics of the repair when you get her back.
    Old 07-02-2014, 10:51 PM   #14
    ipgregory's Avatar
    My Model: Z308
    Send ipgregory:
    Thanks guys. Was just embarrassing more than anything being right opposite the ramp.... Then annoying trying to get off it. At least it never touched the hull.
    Will grab some after pics once its back together.
    Ian
    Old 07-02-2014, 11:25 PM   #15
    Sh-- happens!
    Anyone that says they haven't had their moment , or moments for some of us , is lying through their teeth.
    Bet you learned a little something from it , huh.
    Hopefully your on the water for the 4th!
    Motoxxx43 (07-03-2014)
    Old 07-02-2014, 11:28 PM   #16
    ipgregory's Avatar
    My Model: Z308
    Send ipgregory:
    Reminds me of a quote from a safety course. "There are two types of boaters, those who will admit they have run aground and those who wont"....
    I learned where the shallow spot is opposite my local ramp, I know that.
    Ian
    Old 07-03-2014, 12:10 AM   #17
    Topomaps and GPS only go so far!
    Don't sweat it, it will be back on the water soon!
    Old 07-03-2014, 12:22 AM   #18
    Looking at the photo I'm thinking the advantage of an aluminum prop may have been utilized here. They give when a SS won't. May have saved the prop shaft.
    Old 07-03-2014, 01:27 AM   #19
    I think this is one of those situations where the OP should stick with an aluminum prop, particularly if there are sand bars, rock shelves and semi-floating objects where you boat. You will lose very little in performance using an aluminum vs a SS prop.
    Old 07-03-2014, 01:31 AM   #20
    Originally Posted by ColoradoDiablo View Post
    Sh-- happens!
    Yep, i did it once. Hit a rock shelf that i knew was there alongside a route that i've taken the boat thru at least 100 times. Got distracted picking up some M&M's that i dropped and let the boat wander. Sure made a mess of the 90 hp Evinrude that was on my Stingray at the time. From now on i'll get the wife to pick them up for me.....
    Help with prop selection suja415 Prop Talk 1 03-20-2012 02:17 AM
    2005 SX 19 4.3l 190hp Prop Selection adamsrrl Prop Talk 5 10-10-2010 02:26 PM
    prop selection toddandheidicarlson Prop Talk 4 09-04-2010 04:53 AM
    Prop selection Talari95 Prop Talk 3 06-25-2010 12:36 PM
    2350Z/454/bravo 1 prop selection cleah Prop Talk 3 06-03-2009 10:37 AM
    There are 348 users
