'93 MX20 prop issue
Prop Talk
Old 07-29-2013, 03:13 PM   #1
patrickrk is currently offline
My Model: MX20
My Engine: 5.0 LX, Alpha I
Send patrickrk:
Default '93 MX20 prop issue
I've been looking for someone on here with a similar boat. I recently purchased a 1993 MX20 with 5.0L V8 alpha 1 outdrive. Took it out for the first time this weeekend. Not impressed with the time it takes to get on plane. What size prop are you running? I have a 14x23 and imagine that might be part of the problem. I'd like to pull a wake boarder / tuber, but imagine then thing might never plane out. Any suggestions would be greatly appreciated.
  • Old 07-29-2013, 04:10 PM   #2
    Default Re: 1991 MX20 trim switch
    What's your WOT? Need to be right around 4400-4800 rpm.
    That sounds like a lot of prop for that combination.
    Should be a 19p or maybe a 21p , but that's pushing it.
    Old 07-29-2013, 04:36 PM   #3
    A 23" prop is way too much for that combo. I agree with Larry thoughts on the 19" or 21" (at most)
    But since this is now getting into just a prop discussion, i'm going to move part of this thread to the Prop Talk section.
    Old 07-30-2013, 05:19 AM   #4
    Dozer's Avatar
    Dozer is currently offline
    My Model: Z202 shabah
    My Engine: 5.0 liter alpha 1
    Send Dozer:
    19" came on the 20 ft boats with the 5.0 liter. 21" gives a little higher top end but will be high on the revs.
    Old 07-30-2013, 05:46 AM   #5
    Default Re: '93 MX20 prop issue
    And slooowww out of the hole.
    Old 07-30-2013, 01:12 PM   #6
    Not quite. Increasing the pitch lowers the rpms at WOT....
    Personally i would suggest a 20" - 4 blade prop in SS for what you are planning to do.
    Old 07-30-2013, 07:11 PM   #7
    Dozer's Avatar
    Send Dozer:
    Haha. You're right Mikey. Needed some sleep apparently.
    Old 07-30-2013, 08:10 PM   #8
    My Model: MX20
    Send patrickrk:
    Thanks.
    Considering trying the smart tabs first as they are less expensive and would probably be beneficial no matter what prop I end up with.
    Old 07-30-2013, 09:53 PM   #9
    Originally Posted by patrickrk View Post
    Thanks.
    The Smart Tabs will not fix that prop issue. With the 23" you are putting a lot of unnecessary strain on the engine and outdrive at low-mid range speeds and the engine rpms are not getting up into the manufacturer's recommended RPM range at WOT. But.... your boat, your call.
    Old 07-31-2013, 03:00 PM   #10
    My Model: MX20
    Send patrickrk:
    Took your suggestion and just ordered a 20" 4-blade. Will let you know how it works out. Thanks again.
    1991 MX20 in OH raulston88 Mariah Boats For Sale & Wanted 5 07-24-2013 02:02 AM
    93 MX20 Steering Problem ohmymariah General Maintenance 4 10-27-2012 05:25 PM
    Looking for Assistance-Need MX20 Windshield SW4820 Introductions 1 05-26-2010 01:32 PM
    1993 Mx20 salezman Original Mariah Talk 2 07-01-2008 02:22 PM
    mx20 cover MariahMX20 Projects 0 05-06-2008 06:06 PM
    There are 308 users
