Re: Planing issue
And you will definitely either have to have the skeg welded or install a skeg guard. But then i'm not sure there is enough left of the skeg to install a guard..... :shakehead: |
Re: Planing issue
Re: Planing issue
Like a good single malt scotch fed intravenously? |
Re: Planing issue
As much as I love replacing props, I would rather not.....Im not sure of the pitch diameter, no stamping on it anywhere. it is an aluminum prop and thats about all I know....
Re: Planing issue
Re: Planing issue
Re: Planing issue
Re: Planing issue
So I found the stamping....pretty beat up but it is a 19 inch pitch....replacing with an aluminum prop is the cheapest, but not sure if its the most cost effective....thoughts?
Re: Planing issue
Re: Planing issue
Thanks Mikey! Are the props on iboats decent? I found a 4 blade Michigan wheel vortex for $148....
| All times are GMT. The time now is 06:06 PM. |
