New member need help
Sorry I'm a new member/owner of a 2001 Shabah z250 with the Bravo III. I had it out today and it was fine until I tried to shift into gear and felt a slight clunk then it wouldn't move.I shift it to drive or reverse I can give it throttle but it won't move.I can turn the prop left to right and the prop spins freely by hand. Any advise?
Re: New member need help
Hey Dominick, I recently bought a 250. I inquired with a few z250 owners. Just curious where you picked yours up from?
Back to your question- did it work prior to buying it? Is there enough drive fluid? What else do you notice about the drive, movement, sounds, damage? |
So it wont go in gear in either forward or reverse ? I could guess and offer this:
1. Either your shifter cable is out of adjustment and not throwing far enough to engage the tranny. 2. Your drive shaft is broke (been there/done that) 3. The clutch went out inside the upper unit 4. The splines are so warn in the coupler the drive shaft is spinning in it. |
| All times are GMT. The time now is 02:35 PM. |
