Prop
Prop Talk
Old 07-16-2012, 03:44 AM   #1
Chet Williams is currently offline
My Model: Z210
My Engine: 5.7L alpha 1
Send Chet Williams:
Default Prop
I recently purchased a 350 Shabah with an Alpha 1, it has a 3 blade aluminum 19 pitch prop. Has anyone tried a high five or what is my best application (prop) for this motor and boat?
  • Old 07-16-2012, 03:09 PM   #2
    Default Re: Prop
    You need to keep your rpm's within your WOT range. Should be around 44-4800 rpm. I think most guys with your setup are running a 19 or 21p prop. If your looking for more bottom end try a 4 blade 20p. But your going to loose topend. Haven't tried a High Five , but a lot of guys here have and I'm sure they will chime in.
    Do a search and you'll find loads of info on the subject.
    Welcome to MOC!!
    Larry
    Old 07-16-2012, 03:42 PM   #3
    Default Re: Prop
    Welcome to MOC!!
    Larry
    ... x2 !
    Old 07-16-2012, 03:46 PM   #4
    Default Re: Prop
    While you are here, have a read thru our Basic Propellor Rules sticky here in the Prop Talk section.
    Old 07-16-2012, 06:33 PM   #5
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Default Re: Prop
    The highfive is known as a strong pulling prop for multiple tubes/wakeboarders. I put one on mine because of the size of the boat it was really slow out of the hole. I have absolutely nothing bad to say about it except for the price. With a 350 in a 21' boat, I don't think you will need this kind of pulling power. A 4 blade will probably suffice. Unless you just want to spend the extra cash.
    on the flipside, the Highfive does look pretty badass!
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 08-02-2012, 12:44 AM   #6
    Point_Au_Baril is currently offline
    My Model: 202
    My Engine: 5.0L Volvo Penta
    Send Point_Au_Baril:
    Default Re: Prop
    Hey guys,
    I just took my new (to us) 2000 Shabah 202 out on Lake Ontario today. It has a 5.0L Volvo with a 4 blade quicksilver prop - I think it's a 20" pitch (the number on the prop is 21 86 P20). Wide open, trimmed out she only ran about 40 mph. And I'm only running barely over 4000 rpm. I know it should be running higher than that. The hole shot isn't that great either.
    Suggestions? I think I need to drop to a lower pitch. I think I should be getting in the high 40s - if not 50 - mph.
    It's not that I have a need for speed. I just want the boat set up correctly so that it runs how it should with WOT.
    Neil
    There are 271 users
