-   -   Help with prop selection (http://www.mariahownersclub.com/forum/prop-talk/6580-help-prop-selection.html)
suja415 03-20-2012 01:05 AM
I have a 2000 222 with a new 350 Mag and bravo III outdrive. I was able to get the boat out to do the engine break in and made a few WOT passes. I got 3900 rpm trimmed out and 45.7 mph on GPS. Lake elevation is 6100ft. Oh, and this was with 3 people and full tank of gas.
It has 24P 3 blade props with a 1.80 gear ratio in the drive. I was told by the engine builder that I could safely push 5000 rpm but I don't want to wear it out to soon so my target is 4800. I would like some input on 3 verse 4 blade props and what pitch to go with.
I figure 20 pitch should get me 4700rpm and a 19P about 4900 on 3 bladed props. What would it be for 4 bladed and what are the pros and cons?
Thanks in advance.
voodoo 03-20-2012 02:17 AM
Re: Help with prop selection
Thanks in advance.
I find my four blades let the revs spool up without too much initial propulsion, plane faster.
I'd think, if I were you I'd try a 21, cheaper than a 20.
