-   -   Prop Change repair (http://www.mariahownersclub.com/forum/prop-talk/6174-prop-change-repair.html)
wcso909 09-28-2011 01:28 PM
Re: Prop Change repair
The picture that Digger Dave posted shows a beveled lock. This steel tube is round, Im confused now.
darkcalling 09-28-2011 01:38 PM
Yeah thats a prop lock had the exact same one on my old boat. I heard a guy say he had to tack weld a nut to the top of the lock so he could use a ratchet to remove it but I would go easy with the heat. Hope that helps.
mikeyt 09-28-2011 02:07 PM
Have a look at the .bmp attachment & you will understand. The pic showing is actually the removal key.
darkcalling 09-28-2011 02:30 PM
Yeah what Mikey said that is the key, and the weld on the nut on top of the lock basically is kind of the same theory I guess.
Dredd 09-28-2011 02:30 PM
http://www.psarema-skafos.gr/files/P...bo%20Photo.jpg
