1994 barchetta z192 prop advice
Prop Talk
Old 06-30-2011, 01:57 AM   #1
Stutterin_nate is currently offline
My Model: z192 brachetta
My Engine: 4.3L alpha 1
Gallery Images: 3
Send Stutterin_nate:
Default 1994 barchetta z192 prop advice
The prop that is on the boat now is a 17 pitch (there is a 17 stamped on it i don't know for sure) Stainless steel 5 blade. the engine is a 180 hp 4.3LX. Is this a good one or something i need to look into replacing?? Thanks!!
1994 mariah barchetta z192
  • Old 06-30-2011, 03:11 AM   #2
    Default Re: 1994 barchetta z192 prop advice
    What kind of performance are you getting? Top speed (via GPS if possible)? RPM's at top speed? What do you use the boat for mostly; cruising or towing tubes/skiiers/wakeboarders??
    Old 06-30-2011, 03:29 PM   #3
    Gallery Images: 3
    I havn't got the boat in the water yet. i bought it a few weeks ago and hopefully today after i redo the carb i will get er on the water and find out.
    Old 07-02-2011, 02:00 AM   #4
    Gallery Images: 3
    i am getting around 4900 rpm's WOT and around 40 mph without a gps to verify. mainly we will be cruising and pulling tubes. i asked because a couple of people said 5 blades is too much. i have a 3 blade ss prop on a bad outdrive but i can't see nothing stamped on it to know pitch....
    thanks!!
    Old 07-02-2011, 04:23 AM   #5
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    On our 1994 182 Barchetta, with a 4.3L MerCruiser V6, 4bbl carb, Alpha 1 drive with 14x23 aluminum 3-blade prop I get 45MPH (by the speedo) at 4800 RPM WOT.
    Too much what?
    Mainly a five-blade is going to give you better hole shot with somewhat lower top end (probably), for the same size and pitch prop.
    With a tube you're not so much worried about hole shot, like you are with skiers. Sounds like your current prop is about right. You could try going down an inch in pitch, which may improve everything, all around, or not.
    The science and engineering can only predict gross effects. I.e.: More pitch leads to worse hole shot, but more top end and better fuel efficiency. Less pitch the opposite. But, from what others reported here, our boat shouldn't do well on hole shot with a 23 pitch prop, but she does. Even with four people in the boat, she pops up on plane like a cork. Has a decent top end and gets pretty good fuel economy. We lucked-out
    Point is: Prop selection can be a hit or miss proposition.
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 07-02-2011, 03:00 PM   #6
    Gallery Images: 3
    thanks!!
    Old 07-04-2011, 10:51 PM   #7
    Jim's boat is a rarity that can run a 23" prop and i'm a little bit envious. Dont expect your boat to do so too. Your prop will be stamped at the front on the inside of the hub. I'm guessing (as Jim did) that you are likely using a prop that will work but its clear the boat isn't performing like it should. I suspect you could run a 19" 3 blade and get slightly lower (200 or so) rpms and a little more speed at top end without losing much low end grunt. The drop from 5 blades to 3 blades will offset some of the rpm drop you normally get when you increase your pitch by 2" (which would be about 400rpm).
    Used boat advice- 93 Diablo vs 95 Barchetta boatmansteels Original Mariah Talk 4 04-22-2010 02:28 AM
    Barchetta Z192 rtopedvm Original Mariah Talk 0 09-30-2009 02:39 AM
    1994 182 Barchetta? SEMIJim Original Mariah Talk 3 06-22-2009 02:20 AM
    speedometer 94 Z192 Barchetta calcutta Original Mariah Talk 1 05-13-2009 09:08 PM
    How did I do? First Boat 1995 Barchetta Z192? jkboliphant Original Mariah Talk 4 02-27-2009 01:40 AM
    There are 239 users
