z280 props
Prop Talk
Old 05-31-2011, 10:58 PM   #1
warner0308's Avatar
warner0308 is currently offline
My Model: z280
My Engine: 454
Send warner0308:
Default z280 props
any body know what were on these? i got bravo III with i think 26 p. it plains for crap only turns 4000 rpms. any sugestions. thanks tom
  • Old 05-31-2011, 11:56 PM   #2
    Default Re: z280 props
    Dropping down to 24" props will increase your WOT rpms approx 400-500 and should help with the planing problem. You might want to be sure what props are on the boat now though before you go & purchase a new set.
    Old 06-01-2011, 01:35 AM   #3
    warner0308's Avatar
    My Model: z280
    My Engine: 454
    Send warner0308:
    they were 24. my wife hit something and took them out. these are a buddys and were laying around. i thought they might get me some more mph but i got less. 24 didnt come out that great either. bow down trim down still didnt like getting on plain (454 efi)
    Old 06-01-2011, 03:08 AM   #4
    The 24's were likely what was original with the boat and dropping all the way to 22" will bring up your WOT rpms to about 4800-4900 which is way above the recommended 4200-4600 range for a 7.4mpi, if you are at 4000 with the 26" props. With a boat your size & weight it's critical that you get the props right for the best performance. You should be up around 45-47 mph at WOT with that 7.4. If you have a 454MAG though you have some room for the 4" prop drop as the recommended rpm range is 4600-5000. Going down to a 22" set though will likely leave you a little short of 45mph but it should literally pop out of the water. Does your boat have trim tabs?
    Old 06-01-2011, 03:17 AM   #5
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    I would say 24's would still be the right ones. Do you have trim tabs on the boat? If not then get them. Aint no way this boat is going to hit 50mph though. Also keep in mind the health of your engine. Its only natural for performance to drop off over the years from when new.
    Old 06-01-2011, 03:22 AM   #6
    warner0308's Avatar
    My Model: z280
    My Engine: 454
    Send warner0308:
    its got 7.4 mpi yes trim tabs. the best ive got the boat was 39.8 on gps with the 24p tach didnt work then. i was hoping for 45 mph. the 26p is 36mph under 4000 rpms. trim tabs down trim down, slugish. trim up a little,tabs up a little, then trim up a little again and it goes. then tabs to adjust ride!
    Old 06-01-2011, 04:06 AM   #7
    rajjneef's Avatar
    My Year: 97'
    Gallery Images: 3
    Send rajjneef:
    Short of building in more horsepower I dont see any way of getting it up to that speed. I was guessing you were probably around 40-42 mph. If 24p and trim tabs isnt getting you out of the hole like you want you may be forced to go 22p. The problem is your speed is really going to suffer. Its always a tradeoff so if you really want more speed you may hate it. As much as I love speed I like to be able to instantly feel it when I push the throttle. I think if you buy new they offer a 23p with a higher cup which may help.
    Old 06-03-2011, 05:26 PM   #8
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    I called Arizona Speed and Marine last week about re-flashing my ECM to get more power.
    ECM/ECU Tuning
    On my standard 7.4 they claim 14-20 more HP and will add 400 more rpms. They can get rid of the low end bog (over rich condition) & gain fuel economy.
    Its' like $400. Best dollar per HP gain you can buy.
    2000 Z302 Bow Rider
    24p bravo 3 props Oregondunes Other For Sale 1 01-18-2011 06:41 AM
    Props props props blockp Prop Talk 14 07-06-2010 07:12 PM
    Props? boarder1010 Prop Talk 28 08-07-2008 01:46 PM
    Props coxgreen Prop Talk 27 05-30-2008 12:02 PM
    Polishing Props S.L.P. Prop Talk 5 01-29-2008 08:56 AM
    There are 308 users
