Prop question
Prop Talk
Old 03-14-2011, 07:43 PM   #1
Purple_Shabah's Avatar
Purple_Shabah is currently offline
My Model: Shabah 182
My Engine: 4.3 Apha
Gallery Images: 19
Send Purple_Shabah:
Default Prop question
I'm thinking about upgrading to a stainless steel prop for this spring and I'm just wondering what size would be the best to go with.
I thought maybe a little better hole shot would be nice as the top speed is already faster than I normally would go, maybe a little better fuel economy wouldn't hurt.
Not much water sports, mostly just cruising the lakes and bar hopping by water
The boat is a 182 Shabah with a 4.3 Mercruiser.
Anybody have any thoughts? or good suggestions?
Spring is coming
Time flies when you're having rum.
  • Old 03-14-2011, 08:43 PM   #2
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Default Re: Prop question
    if you have an aluminum one now, just switching to a stainless will do all that you've just described your looking for.
    the aluminum props flex and stainless way less.
    might think about this.............if you have a 3 blade, switching to a 4 blade (better hole shot, less top speed), then if you do and you have a 21p now, switching to a 19p (again better hole shot, less top speed). I strongly disagree with reducing overall diameter.
    2000 Z302 Bow Rider
    Old 03-14-2011, 11:42 PM   #3
    I run a 4 blade 20" SS prop on my 180 which for me is a good mix of cruise & water sports. I wouldn't drop to a 19" - 4 blade from a 21" - 3 blade though as you would add about 5-600 rpm at WOT which may put you well over your recommended range of 4400-4800rpms at WOT. What prop do you have on now?
    Old 03-15-2011, 12:08 AM   #4
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    I'm not really sure, it's encased in tarp in a shelter and covered with snow right now so I can't get at it, but here's a picture of it if that helps.
    I had a stainless steel prop on my last boat (140 horse Evinrude outboard) I liked it a lot more than this aluminum one.
    http://P1010256.jpg
    Or here:P1010256.jpg
    Old 03-15-2011, 03:28 AM   #5
    uh, yep that looks like a prop.
    Old 03-15-2011, 01:19 PM   #6
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Ha Ha, yep that's what they look like! You can tell it's a picture from last spring. Look no nicks on it and is that green grass??? boy I've forgotten what it looked like
    So ya, I can't really tell what size it is, I just thought some members here could give opinions on what pitch/size has worked best for them.
    Old 03-19-2011, 01:17 PM   #7
    bbrophy58's Avatar
    bbrophy58 is currently offline
    My Model: 182 shabah
    My Engine: 4.3 alpha 1
    Send bbrophy58:
    Hi Purple. I have posted a few times here on props and have gotten great advice from Mikey. I have a 182 Shabah with the 4.3 in it running a 19 pitch aluminum prop. It has great dig and a top end that varies from 46 - 48. I have this obsession with hitting 50 mph, so I bought a 21 pitch Turning Point Hustler aluminum performance prop for about 120 dollars. I will test it out next month and post results. I have to say, my guess is that the 19 is best......but we will see. I would love to hear your numbers with the 19 ss. RPMs, speed, hole shot, etc. What are your numbers now?
    Old 03-19-2011, 01:56 PM   #8
    I'd be interested in hearing what the Turning Point prop does. Keep us informed!
    Old 03-22-2011, 02:01 AM   #9
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Ya, me too! Let us know.
    Old 03-22-2011, 09:51 PM   #10
    bbrophy58's Avatar
    Send bbrophy58:
    We are getting 5 inches of snow tomorow in New England....so it may be a little while before I can test her out. I will definitely post results.
    350 Mag prop Question?? bantamboxer Prop Talk 11 08-17-2011 10:52 PM
    Prop question ? karmann Prop Talk 4 09-04-2010 04:04 AM
    Prop Question karmann Prop Talk 5 08-05-2009 02:27 AM
    Just another prop question MtTalari Prop Talk 8 07-25-2008 02:41 AM
    another prop question mariah2350sc Prop Talk 8 07-17-2008 03:45 AM
    There are 312 users
