Speed/RPM/Prop questions 1998 Shabah 202
Prop Talk
Old 09-30-2010, 08:59 PM   #11
al levy is currently offline
My Model: 272 shabah
My Engine: 7.4 bravo 111
Send al levy:
Default Re: Speed/RPM/Prop questions 1998 Shabah 202
is thios yamaha going to fit plus the rake on an outboard is ususally different which is always a concern. try it as if you would use it if you can meaning same amount of weight in the boat and water conditions. lots of luck
  • Old 09-30-2010, 09:35 PM   #12
    845paulg is currently offline
    My Model: Shabah Z 272
    My Engine: 7.4 L MPI Bravo III
    Gallery Images: 12
    Send 845paulg:
    For your motor and boat size, I would go with a 19 pitch, 3 blade SS prop and a hydrofoil. No trim tabs needed. I'm suprised you could get on plane with a 21 pitch. I had a 20 foot Genesis with a little worked 5.0 LX and the boat did 60 with a 19 pitch prop. When I got it over 50 mph it was scary fast for the size of the boat. When I took out alot of people and we were sking, I would install the 17 pitch prop for a better hole shot. Good luck!
    Old 10-01-2010, 02:41 AM   #13
    Originally Posted by JRCustomCar View Post
    . I've been looking into 4 blade 20p, there's a stainless one in my area for $175. I've heard that you lose a bit of top end with the extra blade, but holeshot is much improved.
    That wouldn't have been because what i wrote in post #2 would it?
    Dont stick an ugly hydrofoil on the outdrive......it makes the boat look like something out of a low rent trailer park in Arkansas.
    The 22" 4 blade will lower your rpms slightly and that's not something you need to do. The 20" 4 blade or even a 21" 4 blade if you can find one would be a better option. You need to get your WOT rpms as close to 4800 as possible for maximum efficiency. You are not going to hit 50mph with that boat/motor combo anyway and most people i know dont run at top speed so there's no point in pursuing that. Either install a set of Smart tabs or even a set of electric or hydraulic tabs if you have the extra $$$ in your pockets which will help get you on plane quicker and hold plane at lower speeds.
    Old 10-01-2010, 10:30 PM   #14
    JRCustomCar's Avatar
    JRCustomCar is currently offline
    My Model: Shabah 202
    My Engine: 4.3L Alpha One
    Send JRCustomCar:
    Thanks mikey, a hydrofoil was never even a consideration for me. Too much instability/porpoising at higher speeds. I've actually just been looking around to see what's available locally, and that prop was one on there that I noticed. I would be demoing it on my own boat with my own outdrive...
    Old 08-16-2014, 04:43 PM   #15
    badjudgement is currently offline
    My Model: Z2350
    My Engine: 454
    Send badjudgement:
    Remember that your buddy's Rinker has a pad hull at the rear and this is a fast hull but your Mariah will ride better in the chop because it has a true v hull. My Rinker 202 captivating with a 350 mag only topped out at 56 mph on GPS so a 4.3 hitting 58 is almost not believable, maybe 48 mph... unless it's an 18 foot boat.
    Old 08-16-2014, 04:56 PM   #16
    Try to look at the dates of the prior posts before you reopen a 4 year old thread...
    Old 08-16-2014, 04:57 PM   #17
    This thread is 4 yrs old.
    The OP hasn't been on the site in over a year.
    Best to PM him.
    92 Mariah Z240 prop questions lowerthanu Prop Talk 3 05-31-2010 02:40 AM
    more prop questions jeffro788 Prop Talk 14 04-23-2010 05:15 PM
    1998 Jubilee 204 - Need Prop Help Taylor-played Prop Talk 2 08-07-2009 05:56 PM
    1996 Shabah 180 3.0 top speed? midwest mariah Original Mariah Talk 4 08-03-2009 04:43 AM
    Questions about 1998 Z202 Shabah possible z202 Shabah Owne Introductions 2 07-12-2009 02:53 PM
    There are 218 users
