newbie prop ?
Prop Talk
Old 09-20-2010, 02:26 PM   #1
Dern72 is currently offline
My Model: Z210 Talari
My Engine: 5.7L Yamaha
Send Dern72:
Default newbie prop ?
Picked up a 1994 Talari z210 w/ 5.7 yamaha engine and outdrive a couple weeks ago. have had her out the past two weekends and every things seems to be fine. Boat came with a 15 inch 15 pitch 3 blade Alum prop. With this prop the boat will turn around 5200 rpms at W.O.T. While cleaning up in the engine bay last night i found a placard that says W.O.T rpms should be between 4200 and 4600 rpms. We will using the boat mainly to do a little tubing and some skiing so top end speed is not a concern, but should i be getting a diff prop to bring the W.O.T rpms in to the factory specified operating range? And if so what prop would you guys recommend?
Daryn
  • Old 09-20-2010, 03:20 PM   #2
    Default Re: newbie prop ?
    A 15" pitch is a little too much and you are overworking your engine. With each 1" increase in pitch you will drop your WOT rpms by 200 or so. I would suggest you look at a 17" 3 blade or an 18" 4 blade which will give you a little more top end, drop your rpms to the 4600-4800 range and shouldn't sacrifice your towing ability.
    Dern72 (09-21-2010)
    Old 10-01-2010, 06:31 PM   #3
    Send Dern72:
    Mikeyt, thanks for the info. The prop I am looking at is 4 bladed 18 pitch with a 14 1/8" diameter. Will switching from a 15" diameter have any effects on performance?
    Daryn
    Newbie L&K's Z 190 Shabah Introductions 2 07-20-2010 11:07 AM
    Newbie Dmil Introductions 4 04-01-2010 12:28 PM
    Prop question from a newbie SamnBonnie Prop Talk 12 09-16-2008 03:53 PM
    Another Newbie 97180SE Introductions 3 08-18-2008 05:27 PM
    Another Newbie bburgess9 Introductions 3 06-19-2008 10:32 PM
    There are 319 users
