-   -   kamper (http://www.mariahownersclub.com/forum/prop-talk/4216-kamper.html)
jsk9675 06-07-2010 12:55 PM
kamper
need to replace a damaged prop on my 1997 Talari 209 can not find markings on old prop what was original equipment prop on my boat need to know diameter & pitch she has a 5.7LX Alpha 1
thanks
mikeyt 06-10-2010 03:54 PM
Re: kamper
It would help considerably to know what prop is on the boat now. The stamped markings should be on the inside of the prop hub. They're usually marked as either a size (ie 14.25 x 19) or a model #.
There is really no such thing as "original equipment" with props. Props were usually supplied by the original vendor depending on what usage was planned for the boat. I would suspect yours was supplied with either a 19" or a 21" pitch 3 blade prop. A 19" would give lots of low end & mid range grunt while sacrificing a bit off the top end. The 21" would give decent mid range with a higher top speed but will sacrifice the low end. A 20" 4 blade would split the difference.
jsk9675 06-11-2010 01:45 AM
Re: kamper
Mikeyt
Thanks for the info it is helpful and I will look again to see if I can find any #s or marking on the inside of the hub
