-   -   Z272 with a 502 Bravo I (http://www.mariahownersclub.com/forum/prop-talk/4178-z272-502-bravo-i.html)
apickens99 06-02-2010 09:49 PM
If any of you have the 272 with a 502 Bravo I setup, I'd be curious to know what size and brand of prop you are running. This is the first summer with the boat and I think it is propped too much. I can only hit around 3800-4200 RPM with 6 people depending water conditions. The engine speck is 4600-5000 RPM at WOT I believe. The boat also seems sluggish out of the hole and has trouble plaining out it also wants to cavitate when going into a turn. It currently has a Mirage Stainless Steel 23p 3-blade prop. I am considering going to a 19p 4 blade setup. Any suggestions.
mikeyt 06-03-2010 01:17 AM
Re: Z272 with a 502 Bravo I
That change will add about 900 rpm at WOT so if you are hitting 4200 now you will be over the recommended range. I would suggest a 19 - 3 blade or a 20" - 4 blade.
