just saying hi
Prop Talk
Old 04-10-2010, 04:40 PM   #11
Default Re: just saying hi
Originally Posted by todd miller View Post
where can i find the ratio to the outdrive
Here's WetWilly's guide to finding the gear ratio on Bravo outdrives:
Drive Unit Gear Ratio Identification
All Bravo drive unit gear ratios are identified on each drive in two places:
A) The first place to look is on the decal on the port side of the drive housing. It will have a number such as (1.50R) and then the seal number.
B) The second place to look will be on the universal joint splined yoke. It will be identified with a letter such as (F). This method is explained in the following chart and is true for new or un-tampered with drive units. A drive unit could have had the gear ratio changed for high altitude, which would void out any application of the following chart.
The gear ratio then would have to be determined by counting the teeth on the drive gear and the driven gear in the drive shaft housing and using the following chart for reference.
Bravo Three
U-JOINT IDENTIFICATION:
RATIO U-JOINT SHAFT MARKING
2.43:1 N
2.20:1 K
2.00:1 B
1.81:1 G
1.65:1 C
1.50:1 F
1.36:1 P
NUMBER OF TEETH PER GEAR - DRIVE SHAFT HOUSING:
RATIO – DRIVE / DRIVEN
2.43:1 - 23 / 30
2.20:1 - 23 / 30
2.00:1 - 27 / 32
1.81:1 – 27 / 29
1.65:1 – 27 / 32
1.50:1 – 27 / 32
1.36:1 – 27 / 29
Here's the info on Alpha outdrives which is similar if not the same method as the Bravo:
todd miller (04-11-2010)
    There are 267 users
