11-14-2011, 08:36 AM
#18
spinks99 is currently offline
My Model: Z202 Shabah
My Engine: 5.0 LX Alpha One
Re: Stainless 3 Blade Z212 5.0
Hey 95Z212,
I have a 95 Z202 with a 5.0 LX (4 barrel). I don't have any problem getting on plane. I had an 18P Stilleto (too small). Now I have a 21P High Five (1.62 gear ratio). I can take 9 people all day and still enjoy water sports.
It sounds to me that you have engine problems (carb problems, missing, timing, coil going bad). Check your drive position when planing (all the way down). It sounds dumb, but visually check and see that it is all the way down.
Also, you probably have that awful Mercruiser 3000 throttle and shifter. Make sure it's opening the throttle all the way up. Mine is so stiff I'm replacing it this year. When people pull me skiing, they often think the throttle is wide open when in fact it's about half way.
If you have the 2 barrel 5.0, I think that has less power than mine, but planing should not be a problem.
Danny
