Diablo w/ 4.3 has trouble planeing, Prop size?.
Prop Talk
Old 05-28-2009, 07:54 PM   #1
Rick of Austin's Avatar
Rick of Austin is currently offline
Gallery Images: 4
Send Rick of Austin:
Default Diablo w/ 4.3 has trouble planeing, Prop size?.
I have a Diablo with a Alpha One 4.3 v6 that is a great little boat when its just my lightweight girlfriend and I.
When we add 3 young teenagers it barely gets on a plane, I have to have 2 off the kids get in front.
The prop is a quicksilver stainless with 21 pitch.
A local dealer thinks I should go to a 19 pitch but wants me to record rpm numbers first which I havent done.
Does anyone have any suggestions as to what prop would work based on your experience?
Rick in Austin
  • Old 05-28-2009, 08:04 PM   #2
    Gallery Images: 4
    Default Re: Diablo w/ 4.3 has trouble planeing, Prop size?.
    I think its a 1993 but am unsure without looking at my manuals, can you guys tell by this pic?
    Old 05-28-2009, 08:18 PM   #3
    depman160's Avatar
    depman160 is currently offline
    My Model: 2000Z
    My Engine: 5.0L Merc Alpha 1
    Send depman160:
    funny, I see no boat in that pic......
    but I can understand your issue. My 1992 2000Z with the 5.0L has the same issue planing off. I don't know my prop's pitch, but I assume if I were to change it, it would make a difference.
    If only it could be summer all year long!
    Old 05-28-2009, 08:44 PM   #4
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    Uhhh, what was the question again? yeah, she looks like an early 90's model
    There's a couple threads going in the props forum that might help. But generally a lower pitch will get you out of the hole quicker. definitely record your WOT rpm before going down though. If you're already running at max rpm, you might have go to a 4 blade or something bigger to help keep the rpm's down with the lower pitch.
    Old 05-28-2009, 10:00 PM   #5
    Kitto's Avatar
    Kitto is currently offline
    My Model: 2002 Diablo 200 5.0L Merc. Alpha 1
    Gallery Images: 7
    Send Kitto:
    [QUOTE=blockp;14716]Uhhh, what was the question again? yeah, she looks like an early 90's model
    Early 90's??? I'd say late 20's at best.
    I would definately go Stainless on the prop, whatever the pitch. Worth the money. Good luck
    Kitto
    2002 Diablo 200 5.0L Alpha 1
    Old 05-29-2009, 02:39 PM   #6
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    She looks older than 16. I think we'll need more pictures to be sure...
    x2 on getting the numbers before you re-prop. Obtain your WOT rpm, your top speed (gps would be best). If you know (or can find out) your drive ratio and the approximate weight of your boat (93 brochure lists 2200# for the Diablo), you can use the mercury prop calculator to see what prop would be a good fit to your boat.
    Mercury Prop selector
    My Mariah
    Old 05-29-2009, 03:05 PM   #7
    Gallery Images: 4
    Thanks guys, good advice and I will sure follow it.
    Lauren will also appreciate that she looks like she is in her late 20s!
    She just turned 32 and its killin her
    I have been teaching her to fly and she has become a darn good pilot, now that the summer is here we are putting the little Diablo to very good use.
    Here are some pics of the boat, Lauren and the planes.
    http://www.flickr.com/photos/38883018@N07/
    Old 05-29-2009, 06:42 PM   #8
    depman160's Avatar
    My Model: 2000Z
    Send depman160:
    Today is my 39th birthday, so tell her to just be happy that she will never be as old as me!
    Old 05-29-2009, 07:41 PM   #9
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    32??
    I've got socks older than that!!
    Smart tabs first, (cheaper than a new prop), if that doesn't change anything, (bet it will), then try a 19 SS prop.
    Old 05-30-2009, 05:16 AM   #10
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Smart Tabs will definitely help, but let's get these numbers before anything (especially the girlfriend's, but understood if they're missing from your response)!!
    The only way to really "tune" in on a correct prop size suggestion is to know the current max speed, RPM, gear ratio, etc. as already pointed out. Another factor - what's the condition of the current prop?
    21 pitch is a tad bit high for the 4.3, but definitely doable. Does your boat "growl" at all while idleing or turning? That could be the gimbal bearing which robs power when it goes bad. Also, what 4.3 is it - standard or LX (what horsepower)?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    prop size keith tindling Prop Talk 2 07-03-2009 03:33 AM
    looking for prop size shabah z202 5.0 scottmori Prop Talk 6 05-29-2009 03:57 AM
    Ran into some trouble Mike S Original Mariah Talk 14 05-26-2009 06:05 PM
    Engine trouble grommett Original Mariah Talk 5 04-26-2009 09:09 PM
    PROP Size? TALLRAM Prop Talk 4 07-28-2008 05:07 PM
    There are 224 users
