Good prop for 1999 Shabah z212 w/ 5.7 L mercruiser 2bbl carb
Prop Talk
Old 08-06-2020, 07:14 PM   #1
maoen73 is currently offline
My Model: 212 Shabah
My Engine: 350 mag
Send maoen73:
Default Good prop for 1999 Shabah z212 w/ 5.7 L mercruiser 2bbl carb
Just looking for some help on a new prop. Went to a new lake this past weekend and ruined prop. Pulled off old prop but stamp is unreadable to know what was on the boat. I was always happy with performance of old prop. I have a 1999 Shabah Z212 with the Mercruiser 5.7L 2bbl carb and no modifications with Alpha 1 outdrive (unsure of gear ratio). I measured old prop from center to edge and get 7.5 inches (15 inch prop). Just not sure on pitch. The more I read on props the more confused I get. We do tube/ski/wakeboard from boat. Boat at 800-1000' elevation. Thanks in advance for any help
  • Old 08-07-2020, 01:19 AM   #2
    Default Re: Good prop for 1999 Shabah z212 w/ 5.7 L mercruiser 2bbl carb
    I'll assume you had a 3 blade prop so you probably had a 19" pitch prop with that boat.
    maoen73 (08-07-2020)
    Old 08-07-2020, 01:33 PM   #3
    My Engine: 350 mag
    Send maoen73:
    Thanks for the help mikeyt. I was hoping you would help me out. So a 19 pitch 15 inch prop makes sense for my set up? Based on all the past posts I read through 19 pitch seemed to be talked about as the most common pitch for similar boats. Wasn't as sure on diameter or how much an inch difference in diameter makes. Thanks again.
    Old 08-07-2020, 10:58 PM   #4
    Anything between 14" and 15" diameter should be fine.
    Wanted: New owner. 1999 Shabah Z212 5.7L BravoIII. NEED PARTS!! Help! Wfn1999 Mariah Parts For Sale & Wanted 13 05-19-2017 02:59 AM
    1999 Z212 Shabah with 350 Mag indykoch Mariah Boats For Sale & Wanted 3 05-22-2012 03:14 PM
    1999 Mariah Z212 Shabah cessnaag Mariah Boats For Sale & Wanted 1 06-10-2011 12:35 PM
    1999 Mariah Z212 Shabah indykoch Mariah Boats For Sale & Wanted 3 12-05-2010 01:56 AM
    There are 279 users
