davanti 215 prop
Prop Talk
Old 09-08-2015, 12:39 PM   #1
tuneforlfenjmarine is currently offline
My Model: 215davanti
My Engine: 5.0lx
Send tuneforlfenjmarine:
Default davanti 215 prop
does anyone know what prop came on a davanti 215 cuddy cruiser with a 5.0lx
it had a 14.5" 19p that was bent not sure if that is proper prop
  • Old 09-08-2015, 06:11 PM   #2
    Default Re: davanti 215 prop
    That would be the most likely prop that it came with. Props were usually installed depending on where the boat was destined to. Higher elevations required less pitch in the prop.
    Old 09-08-2015, 07:56 PM   #3
    My Engine: 5.0lx
    thanks brother im having a strange problem with my boat
    i bought to i=use as a chase boat but it wont plane ive tryed everything drained fuel new coil new cap and rotor new wires checked compression timing all good the distributor is not the updated one with black coating on board im about to put a new module and go try her out let me know what ya think i work on boats alot never had a problem like this she idles fine the minute i go wide open she porpouses at 4000 rpm wont plane carb has all four barrels open
    Old 09-09-2015, 04:29 PM   #4
    Porpoising is an easy fix with a set of 'Smart Tabs'. Do a site search (top right corner of your screen) here for 'Smart Tabs' and you will find lots of useful information and lots of individual boat owners singing their praises. Also, check to ensure that the travel of your outdrive comes in far enough to reduce porpoising when planed out.
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    prop suggestion 1994 davanti 454 mag bornmud Prop Talk 1 06-20-2012 12:29 AM
    Davanti 215 SaVee Introductions 1 07-19-2010 04:29 PM
    Mariah Davanti 2210 prop Joycee Prop Talk 6 05-05-2010 01:43 AM
    davanti 235 prop Q's coorsmgood Prop Talk 5 08-31-2009 02:16 AM
    There are 261 users
