cabin fever
Projects
Old 04-24-2013, 06:49 PM   #11
Default Re: cabin fever
Well...........I guess you can run whatever you want. But it's rated at 300 HP.
  • Old 04-25-2013, 03:25 AM   #12
    dcgragg's Avatar
    dcgragg is currently offline
    My Year: 96
    My Model: shabah 200
    My Engine: 5.7
    Send dcgragg:
    I appreciate the input from you guys. i doubt the 383 will make a ton of hp but i was not for sure about the lower unit. just dont want to tear anything else up. as far as the drive shower, does anyone have a link to one that will fit the alpha. or will they interchange. that looks like a lifesaver
    Old 04-25-2013, 04:10 AM   #13
    Here's one I was looking at:
    Alpha Shower
    I'm sure you'll hear about more.
    Old 04-25-2013, 04:18 AM   #14
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    thanks, i can definately see i need to put in for some more overtime at work.
    Old 04-25-2013, 05:22 AM   #15
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    The reason I would be excited for the 383 would be the extra grunt off the bottom for getting a skier or a tube going. The 83 won't make that much more HP but will bring the torque curve in at a lot lower rpm and make it a nice broad, flat one.
    Old 04-29-2013, 12:40 PM   #16
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    over the weekend i replaced the flywheel, starter and changed the oil. started right up with no issues as of now. ready for lake test hopefully my next day off. I am however still going forward with building a 383 to install later this year. eagle 383 crank from kmj performance $198, its mine! cant make up my mind if i should spend the money on a set of h beam rods or not.......thinking maybe i should. no need to cheap out!
    Old 04-29-2013, 01:36 PM   #17
    husker_fan's Avatar
    Send husker_fan:
    H beam rods are very heavy and overkill for what you want to do. Spend your money on something else. Nice intake, carb, etc. If I were to buy a rod for that I'd do the eagle 6" I beams. H beam are made for nitrous, supercharged, etc.
    275 and 302 mid cabin questions sceptre155 Original Mariah Talk 77 12-26-2014 05:58 PM
    Water in Cuddy Cabin Marsh Original Mariah Talk 2 05-11-2011 03:48 PM
    Factory Cabin Top jsburkey21 Original Mariah Talk 4 07-15-2010 05:34 PM
    cabin cupboards roger simkin Original Mariah Talk 0 12-31-2009 07:25 PM
    cuddy cabin lance Original Mariah Talk 2 06-24-2008 01:31 AM
    There are 539 users
