-   Projects (http://www.mariahownersclub.com/forum/projects/)
-   -   Mariah Radio Bezel Refresh (http://www.mariahownersclub.com/forum/projects/7758-mariah-radio-bezel-refresh.html)
John Rush 02-03-2013 12:47 AM
7 Attachment(s)
Recently purchased a Mariah Shabah with a broken Radio bezel and no radio. Hey! No problem, Time to have some fun :D
1) Started out with the basic shell wrapped in color match vinyl
2) Made a paper then traced to cardboard face plate which will be my stencil for the black ABS plastic (Pic)
3) Use an Olfa knife to trace and cutout the outlines of radio, pocket, Kicker bass knob, and power seat switch.
4) Wrapped the ABS panel in Speaker enclosure carpet (used 3M spray glue)
5) Re-assembled the Bezel and then applied two layers of 3M fiberglass mat and resin to add strength for the weight of radio and longevity of the frame.
The radio is a Pioneer FH-X700BT
Attached pictures of each step.
Thanks, John Rush
aubtiger 02-03-2013 01:07 PM
Re: Mariah Radio Bezel Refresh
Thats a great idea and you did a great job. I am doing the same thing with 1/8 thick piece of aluminum. Also doing both switch panels with it. Going to have all 3 powder coated black. I also took some 1/16 thick aluminum and remade my horn cover that was missing when I got the boat and will have it powder coated the same color as the hull.
ColoradoDiablo 02-03-2013 04:39 PM
Nice job John!
It looks factory:wink_thumbup:
John Rush 02-03-2013 09:28 PM
Can't wait to see how that turns out! Great idea with the powder coating. Be sure to post some pictures.
Thanks Colorado
Unknownmariah 05-03-2016 02:01 AM
That looks awesome! I have the same problem...only thing is i cracked my bezel.
