Gin Times '92 Diablo 180
Projects
Old 07-18-2012, 08:46 PM   #1
Gin Time's Avatar
Gin Time is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha 1
Send Gin Time:
Default Gin Times '92 Diablo 180
A few weeks ago we picked up our new to us, 1993 Mariah Diablo 180. She was a one owner that was marina maintained but in need of some SERIOUS TLC!! I thought it would be fun to document her progress from start to finish so here we go.....
POs pic taken from the craigslist ad where I discovered her. OUCH! I knew Mariah is a very well made boat and holds it's value so it was worth the 50 minute trip to the Hampons to check her out.
On our way home with a trailer with one working light and dry rotted tires.
Home in the driveway.
3.0 Merc / Alpha 1
  • Old 07-18-2012, 08:59 PM   #2
    Gin Time's Avatar
    Send Gin Time:
    Default Re: Gin Times '92 Diablo 180
    The very next day we got two new tires and a quote of $2000 and $2800 for a new interior and I started some detailing by using my wheel and some 3M compound. Someone turned the lights out on me so the detailing came to an abrupt halt.
    3.0 Merc / Alpha 1
    Old 07-19-2012, 12:38 AM   #3
    Gin Time's Avatar
    Send Gin Time:
    Here is how she looks today. All stripes removed (heat gun and peel on blue hull and rubber power wheel on the white topsides), wet sanded and power compounded. Weather permitting, I will glaze,polish and wax her tomorrow.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 12:22 AM   #4
    Gin Time's Avatar
    Send Gin Time:
    As she sits on the trailer today.
    3.0 Merc / Alpha 1
    Old 07-21-2012, 12:55 AM   #5
    Gin Time's Avatar
    Send Gin Time:
    Tomorrow we have a full day out with the boat planned. So psyched. BUT, first task is to install all new switches at the helm. I ended up purchasing the switches below at a price match cost of $14.68 each switch at West Marine. Little inside scoop, if you have a local West Marine and shop there, go in and find what you need. Take a minute to look up that exact product number on your cell phone and search the cheapest store you can find it at. Bring your cell to the counter with the page up and whala, instant discount! Fuel pump at West Marine $159, online $109, matched price at West Marine.... yep, $109!
    3.0 Merc / Alpha 1
    Old 07-22-2012, 09:52 PM   #6
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    Great thread! Looking forward to seeing more progress
    -Ryan
    ThunderShark Web Solutions
    Old 08-09-2012, 08:35 PM   #7
    Gin Time's Avatar
    Send Gin Time:
    So I've been off the forum for a few weeks due to a big issue I had..... I blew up my drive! I was out one day pulling the boys on the tube when all of a sudden, nothing! Long story short, somehow I lost drain fluid and the upper gears completely stripped. It took a few weeks but I found a mechanic who only does Merc drives and ended up buying a like new drive from a newer trailered boat. While I was at it I installed a new exhaust flapper and Osco riser.
    Then my wife and I started vacuuming the rug and cleaning the inside a bit. I got so annoyed with the stains and filth of the carpet I began to tear! Well, a little ambitious, yes! See pics....
    Notice I removed the fuel tank. Here's the story ......... I found that over time ton of gunk had settled under the tank clogging up the drain holes down the keel to allow the water to drain into the bilge. I tried drilling a small hole in the lower portion at the bilge and it worked... a bit. So I got a little crazy and drilled a larger hole with a larger bit and guess what?? YEP, drilled into the fuel tank! So out she came. I epoxied the hole with two layers of JB weld two part epoxy puddy and she looks solid. I cleaned the keel and drilled the stringer holes a little larger to prevent further back up. I took the second hole I drilled and made a big cut out so I can monitor the spot puddy on the tank.
    3.0 Merc / Alpha 1
    Old 08-10-2012, 03:00 PM   #8
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Pretty big undertaking! Keep us updated.
    Old 08-12-2012, 10:28 PM   #9
    Gin Time's Avatar
    Send Gin Time:
    * Fuel tank repaired, tested and leak free!
    *Fuel tank repair window cut out and epoxied!!
    *Keel cleaned and water drain holes enlarged and epoxied!!!
    *New carpet installed!!!!
    *New seats installed!!!!!
    Now maybe, just maybe we can get her out on the water tomorrow!!!!!!!!!
    3.0 Merc / Alpha 1
    Old 08-12-2012, 11:44 PM   #10
    Nice job! Looks awesome!
    Larry
    Electrical, starter clicks several times before starting ginodesico Mercury MerCruiser 12 09-12-2015 02:09 PM
    180 diablo diablo dude Introductions 1 06-26-2011 08:21 PM
    Mariah diablo bigdon Introductions 3 01-10-2010 02:40 AM
    1993 diablo 4.3l huntnfish Introductions 12 12-10-2009 03:48 PM
    There are 268 users
