Make Your Own Curved Windshield for $100
Projects
Old 07-05-2011, 02:29 PM   #1
Scleepy1 is currently offline
My Model: Diablo
My Engine: 4.3 alpha!
Send Scleepy1:
Default Make Your Own Curved Windshield for $100
I have a 1993 Mariah Diablo that had a broken windshield when I bought it. I could have had an original glass replacement for a mere $3885. A plastic's company could have provided one if I sent them the window frame and 8 weeks later and around $6-700.
I removed the left front window as they are the same size. I placed double sided tape on the windshield, applied construction paper and traced around the outside edge. I removed the construction paper and cut around the edges including the pencil line. I now had a template for my new window....figure 1.
Next I took small pieces of duct tape and placed them on the inside/outside edge of the left front window. I then took 1x8 boards and cut them to align with the curvature of the window. I numbered these 1, 2, 3, & 4. You also have to measure how far apart each board is from the one next to it. Beings you are constructing the opposite sided window...when you go to construct this form, the one on the top is now the one on the bottom as you will be flipping this form over. This took me about 3 hours to measure.....trim...and construct. It helps to have spare pices of lumber and an air nailer. Figure 2.
I then placed my paper template on the form and traced around the outside edge, so I'd know where the edges should line up when they are heated. Figure 3.
I contacted a glass company and they cut out my template using marine grade plexiglas (1/4 inch thick) for $60. I then used spring clamps and attached the glass to the flat edge of the form. I'd bought a heat gun and started heating away. Do NOT buy the cheapest Heat Gun. After 2-3 hours, I'd returned mine and bought a better gun (Wagner) for $40 dollars. This time I placed the glass in my mold at the curved edge. I'd clamped it with a 1x2 and started to heat away. You have to heat with the curve, going top to bottom.
Plexiglas melts at 250 degrees. My heat gun has a digital readout and I had it way above that. Go back and forth about an inch from the glass. If you nick the glass with the gun it will leave a scar, it will buff out later. The weight of the other end is all it takes for the glass to lay down as it heats up. Don't bother trying to clamp it, if it is not bent all the way..clamping will not bend it further. You may want to clamp it when you are done so it keeps its shape as it cools. You may hear a slight cracking sound as it heats and that is normal. It takes patience and 3 hours to complete this step.
If I had to do it again....I would have gotten some aluminum sheeting used for ductwork and made a mold using that. Put it in the frame and solder the mold in place. The window did need a minor adjustment with the very back upward corner. It is in the boat. Last figure.
The glass was $60, heatgun $40, 1 x 8 lumber $10. Probably 12 hours labor. Saving thousands or hundreds of dollars.....worth it. If you have questions, hit me up.
Greg
nglauer and Dmahn like this.
The Following 3 Users Say Thank You to Scleepy1 For This Useful Post:
Dredd (07-06-2011), mikeyt (07-05-2011), nglauer (06-08-2013)
  • Old 07-05-2011, 04:25 PM   #2
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Default Re: Make Your Own Curved Windshield for $100
    Nice work Greg looks like it turned out very nice.
    darkcalling
    Z 278 Limited
    Old 07-05-2011, 04:39 PM   #3
    My Model: Diablo
    Send Scleepy1:
    Thanks. This boat only had 167 hours on it. I only paid $3200 for it. There have been 2 others exactly (Teal/white) like it in Iowa for sale. One was asking $7295.....another over $6000.... I had no idea windows were that hard to come by!!!! I'm happy now.
    Old 07-05-2011, 08:37 PM   #4
    Excellent information Greg! The only other suggestions i would make, simply cuz i've gone thru this already, is using acrylic rather than plexiglass as acrylic has better UV protection and scratch resistance. Plexiglass is much stronger though and both will show a little bit of distortion when looking thru them. I did mine in 3/16" acrylic and given the cost of replacing with glass, i'm very happy with the results.
    Old 10-15-2011, 07:08 AM   #5
    handis is currently offline
    Send handis:
    Thank you very much Mikey!! I' ll go on trying to find the glass and if I don't I'll finally have to try with the acrylic plastic option...
    Old 06-06-2013, 05:40 AM   #6
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    How is your windshield holding up? I am thinking about "redoing" mine this summer - although I have a friend with a complete windshield that "might" have the same glass as my 01 Diablo, however he has seen the pricing on ebay and doesn't want to budge off the 1800.00 price (even though he has been trying to sell it locally for nearly 2 years lol)
    Old 06-06-2013, 12:14 PM   #7
    My Model: Diablo
    Send Scleepy1:
    Hello again:
    Its holding up really well. Do you know of a product to clean the glass really well. Seems I can't get my boat glass crystal clear!
    Scleepy1
    Old 06-06-2013, 12:28 PM   #8
    Originally Posted by Scleepy1 View Post
    Hello again:
    Scleepy1
    hi Greg
    Check out this link on keeping your marine grade plexiglass clean
    Old 06-06-2013, 02:29 PM   #9
    My Model: Diablo
    Send Scleepy1:
    I can keep the plexiglass clean....its the regular boat glass I have a hard time with. Didn't know if hull cleaner is OK on the glass? Windex....Rainx isn't doing much.
    Thanks!
    Old 06-06-2013, 02:37 PM   #10
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    some friend!
    nglauer likes this.
    I want to make my boat a " Z " scubydo Original Mariah Talk 2 10-11-2010 06:49 PM
    They sure dont make boats like they used to John Miller Original Mariah Talk 13 03-19-2010 10:34 PM
    Want Merchandise...maybe we can make it happen Daxgirl Original Mariah Talk 12 04-16-2009 07:10 PM
    1999 Z-302 project. Make offer. Boatcrazy Mariah Boats For Sale & Wanted 2 11-19-2008 07:44 PM
    Total Members: 18,995
    Total Threads: 13,326
    There are 281 users
