07-01-2011, 10:32 PM
#5
Mariah350 is currently offline
Re: Cracked Steering Console
Originally Posted by spinks99
Hi Mariah 350,
So you think this is a stress crack from the boat itself, or from someone pulling on the steering wheel? My walk through windshield needs a little coaxing to get closed as well. I need to spread the windshield a little bit. There seems to be some misalignment there. Other than that the boat seems solid. I'm just not getting that solid feeling driving the boat like you would in a Lexus. Do you know what I mean? It seems flimsy.
Danny
Yes, the crack is from stress in that particular spot not from turning of the wheel. I also had the same issue with the walk through windshield. Sometimes after hitting a good wave or wake the boat would flex and the walk through windshield would fall in and I would have to separate the the port and starboard consoles enough to pull the windshield up and back into place.  I fixed the problem by riviting a strip of aluminum to the end of the walkthrough windshield so that it had a little more overlap over the main starboard windshield to prevent the collapsing. I am sorry to have to criticize my boat this way but It should have been discovered at the factory. There are several other issues I had to fix over the past 15 years of ownership but all in all I love my Mariah.
This crack is not a fiberglass repair. The dash is constructed of plastic and a type of thin vinyl overlay on top. I am still contemplating on how to fix this issue.
Take Care
1995 Mariah Shabah 212 Z
Performance Built 355 Vortec
Alpha One Merc Laser II 21''
GPS 64 Mph @ 5100 RPM
