-   Projects (http://www.mariahownersclub.com/forum/projects/)
-   -   Adding accessories (http://www.mariahownersclub.com/forum/projects/4925-adding-accessories.html)
845paulg 09-30-2010 09:44 PM
Adding accessories
I'm adding hydraulic trim tabs, Corsa thru hull exhaust and the telescopic anchor light to my 1996 Shabah Z 272. I was wondering where the switches are located at the hem of the stock Mariahs that came with these options. Thanks, Paul
Tabman 10-01-2010 05:57 PM
Re: Adding accessories
Paul,
I seem to recall that the Trim Tab controls were mounted directly in front of the throttle. Here is a photo I marked with the location.
http://i110.photobucket.com/albums/n...ShabahZ272.jpg
I might be wrong since it's been a while since I have seen that particular boat.
Tom McGow
Bennett Marine
MadMax 10-01-2010 06:40 PM
I have a 1995 Z225 and the trim tab switches are on the dash on the flat section to the right of the built in compass. Not sure if it is the same as your model. Just know mine have been on boat since new.
