-   Projects (http://www.mariahownersclub.com/forum/projects/)
-   -   New engine (http://www.mariahownersclub.com/forum/projects/3460-new-engine.html)
DVoutsas 10-27-2009 09:58 PM
New engine
HI :)
I am a proud and extremely satisfied owner of a 1994 Mariah Shabah 211 boat (The model is identical to the 212 shabah but in Europe it was closed bow and was named 211 ) powered by a Volvo Penta 5.0 Fi /Duo Prop engine { Crankshaft power 235 hp Propeller shaft power 220 hp Engine Weight 930 lb } with F7 stainless steel props .The acceleration was great (I use it quite often for water skiing) and the top speed ( 2 pax and half tank) 55Mph at 4600 rpm (top for Volvo.)
Unfortunately after 14 years the engine died .:mad:
I want to re-power the boat with a Mercruiser 5.0 mpi 260 hp Bravo 3 Engine Weight 1019 lb
My questions are
1) I want the Bravo 3 option but other boaters say that the bravo 3 is not suitable for my boat :confused:because it is to long and weigh more than the Alfa 1 and is not going to give better acceleration or cruising speed (the Volvo duo prop was great)
What is your opinion .
2) I was thinking to install an swimming platform to my boat. How is the extra weight going to affect the performance (Ski towing ski wake Planing and cruising speed)
300sflyer 11-05-2009 11:46 AM
Re: New engine
Sorry to hear your engine died!:(
In order to change to a Bravo outdrive, you need to change out the entire transom assembly as well, as a Bravo drive will not fit on an Alpha or Volvo transom assembly. That is a big expence and really not needed unless you are putting an engine in that is above 300HP.
If it were me, I would simply put in a replacement Alpha engine. Much simpler and much cheaper.;)
Not sure where you are located, but I happen to have a 250HP 5.7 for sale, if you are interested.
New Mercruiser 5.7 350 TKS Engine:eBay Motors (item 330373108267 end time Nov-30-09 08:04:31 PST)
WetWilly 11-05-2009 01:50 PM
Re: New engine
Hi DVoutsas,
300sflyer is correct, is quite a large undertaking to change over to a Bravo 3 setup so if your outdrive is still in good shape, just re-power your Mariah. From what you posted, you seemed quite happy with your original setup and as they say, why mess with a good thing.
See if 300sflyer's 5.7 will bolt up with your Volvo Duo Prop outdrive. The extra HP and torque will probably make your Shabah feel like a whole new boat :wink_thumbup:.
Good luck,
DVoutsas 11-09-2009 07:10 AM
Re: New engine
:)Hi guys
Thanks for your replies. Unfortunately I don’t live in USA I live in GREECE and the shipping for the engine is around 2000 usd .I have already sold the old transom assembly so I am looking for the complete package (engine and transom).
The difference in price between the Alfa And the Bravo complete package is very small.(Maybe our Merc dealer went crazy :yes_grin:)
WetWilly Yes I was quite happy with my original set-up which was a duo prop outdrive ad this is why I want the Bravo 3 (I am a duo prop addict) but I don’t know the differences in performance between the Volvo and the Merc drive(they say that the Bravo 3 is only for big boats )
Waiting for your replies :eek_animated:
Dimitris
