Defogger specification
Projects
Old 06-19-2017, 10:06 AM   #1
John822179 is currently offline
My Model: Z225 Davanti
My Engine: 5L FL V8
Send John822179:
Default Defogger specification
Hello Everyone,
I have a 1994 Z225, fitted with a Pro-Air defogger model 804.
The defogger is rusted solid and is unlikely to work again.
Pro-Air aren't interested in talking to me, so I am looking for a replacement blower.
Does anyone out there know how much air the original Pro-Air unit moved?
I'm thinking about using a Bilge blower, but am unsure it it will shift enough air to clear the windscreen.
Any thoughts welcomed with open arms..
John,
Wine Knot
Castle Archdale,
Lough Erne.
John822179
Mariah Z225 5L V8
Keep the dry side up
  • Old 06-19-2017, 02:38 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Defogger specification
    Not sure of the condition of my blower, but it does not seam to blow a ton of air.
    John
    Thank you Firestone for this useful post!
    John822179 (06-19-2017)
    Old 06-19-2017, 07:08 PM   #3
    My Engine: 5L FL V8
    Send John822179:
    Many thanks Firestone. I guess that any moving air is better than none!
    For 20-30 sterling, it's hardly a fortune if it doesn't work!
    I'll post results in a couple of weeks.
    John
    John822179
    Mariah Z225 5L V8
    Thank you John822179 for this useful post!
    bibleg2015 (06-20-2017)
    Old 06-19-2017, 11:00 PM   #4
    tbrookens's Avatar
    tbrookens is currently offline
    My Model: Shabah Z252
    My Engine: 454 Mag, Bravo 3
    Gallery Images: 2
    Send tbrookens:
    There is a guy parting out a 94 Talari Z. You might want to see if he has the blower?!
    Tracy Brookens
    Old 06-20-2017, 03:28 AM   #5
    My Engine: 5L FL V8
    Send John822179:
    Thanks Tracy, I'll look into that.
    John822179
    Mariah Z225 5L V8
    Old 09-02-2017, 07:54 AM   #6
    My Engine: 5L FL V8
    Send John822179:
    Smile Re: Defogger specification
    As a follow up to my original post, I searched EBay for a replacement and found the following:
    SEAFLO in line blower DC12V. Fits 3" (80mm) intake pipe.
    Has an open flow of 130CFM (3690L/MIN)
    Ampdraw is 2.5A. Fuse size 5.0A
    Built in mounting feet allow easy vertical or horizontal installation
    Low amp draw motor for longer Blower and Battery life
    Four Blade fan Maximise Airflow and Efficiency
    Sealed motor shaft for moisture protection
    Corrosion Resistant ABS Plastic Housing
    Took a bit of fiddling to get it to connect with the flexible hose, but all appears to work ok.
    Enjoy
    John
    John822179
    Mariah Z225 5L V8
    There are 355 users
