Re: Trailer bunk replacement
Look great
Sent from my SM-G900V using Tapatalk |
Wow! That's looks awesome. It's does look so much better black. Great job
I forgot to take a 'before' pic without the boat on it, but here is the result when completed! Did it near the ramp at the lake with some wrenches and power tools, took about 45 minutes total... not too bad!
http://i1216.photobucket.com/albums/...pshe8s7dcj.jpg http://i1216.photobucket.com/albums/...pskwfoaztk.jpg http://i1216.photobucket.com/albums/...pspeoaqrzx.jpg Also took the boat on the first spring drive, it did pretty well! It didn't want to start, even with a brand spanking new battery it acted like it didn't have the juice to crank it (rapping tapping noise when turning the key I believe is starter solenoid) but I turned the crank by hand just a 1/4 turn and it finally fired up right after. Drove it for around 30-45 minutes straight then came back in. After I got home I put my smart charger on the battery and it only showed to be at 50-75% charged, this is a 1000 MCA Exide battery, so I need to dig into that a little more. Once I got it started it ran great though :) http://i1216.photobucket.com/albums/...psr2sdh3vx.jpg |
Excellent work. Everything on your rig looks like new.
Looking real good. Hope mine turns out that well.
Thanks fellas. It's a really nice trailer, I felt like it deserved some love. It really pulls great.
Now if only I could learn to pull the boat on straight every time!!! |
2 Attachment(s)
Just went on the same mission. I bought some trailer bunk carpet on eBay and it was pretty good. I saw the slides people are talking about but they're some type of plastic/composite you screw on top of the carpet. I chose not to use them because the hull would sit on the slides instead of the whole bunk.
As for your boat not starting. Definitely make sure your battery is good but check your ground connections. Especially the one that screws to the back of the block. |
I appreciate the info! I'll get in there and really look at the connections, maybe it will be something simple as some corrosion... |
| All times are GMT. The time now is 02:50 AM. |
