1992 Mariah 2000 ZC Docking Lights Replacement
Old 01-08-2015, 08:42 PM   #1
Michaels1956's Avatar
Michaels1956 is currently offline
My Model: 2000 ZC
My Engine: 5.7/V8 Alpha One
Gallery Images: 4
Send Michaels1956:
Default 1992 Mariah 2000 ZC Docking Lights Replacement
I am going to replace my plastic bow docking lights with stainless steel digital lights. So the ones I have in now are car like old fashion one piece light bulbs with a long tub plastic tunnel to disperse the light. Any ideas to where I might find some updated digital lights that would fit the cutout already cut by Mariah builders in 1992?
  • Old 01-14-2015, 01:22 AM   #2
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    Default Re: 1992 Mariah 2000 ZC Docking Lights Replacement
    To add it would be nice if the digital docking lights fit in the same cutout so they look original and professional.
    Old 01-15-2015, 06:04 PM   #3
    Chris B is currently offline
    My Model: Z260 MCC
    Send Chris B:
    Michaels1956, One of the problems you may run into is the angle of the hole after you remove the tubes. You may be stuck using the tubes. Check out "Mariah Headlight - Halogen to H.I.D. Upgrade" in the How To section in this forum, may give you some ideas. After I get my engine fixed or replaced the docking lights may be a project I look into. Mine are not bright enough to be much help. The tubes on the Z260 are stainless steel so I would not be looking to replace them. Good Luck
    Chris B.
    1998 Z260 MCC
    7.4 MPI Bravo III
    Thank you Chris B for this useful post!
    Michaels1956 (01-15-2015)
    Old 01-16-2015, 06:27 AM   #4
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    My docking light tubes are white plastic instead of stainless. One of my bulbs are burned out on the port side so I will end up changing them sometime early spring. I think the standard fixtures are pretty bright because when I turned on my docking lights the starboard lit up and was pretty bright. I may change out to digital if I can find a digital light that will fit the cutout hole perfectly.
    My main concern right now is replacing both cracked exhaust manifolds with aluminum manifolds and putting a closed cooling system on my Merc-Cruiser engine and get rid of the salt water cooling running through my engine block and manifolds. :-)
    My 1992 Mariah 2000 ZC Michaels1956 Introductions 4 01-08-2015 06:25 PM
    Docking Lights ColoradoDiablo Original Mariah Talk 6 01-31-2014 06:05 AM
    Docking light 1992 2200z bradyweeble General Maintenance 5 05-17-2013 07:04 PM
    LED Docking lights for your Mariah mikeyt General Maintenance 16 06-18-2010 11:31 PM
    Replacement Docking Lights plenty Original Mariah Talk 1 09-25-2009 10:37 AM
    There are 283 users
