| Motoxxx43 |
11-08-2014 01:58 AM |
Re: Old gas!!!???
If you have a carbed model I suppose you could disconnect the fuel line going into the carb and run it into your container once the ignition is "on". Or on the floor over the tank there should be an access point. It is prob about 6-8in in diameter and gives one access to fuel meter. The fuel meter is held in by 5 or 6 screws and once removed it leaves you a nice hole you can get a pump in to suck it out. OR you can always have a boat shop suck it out. Then you dont have to worry about disposal.
