Transom shower pump question?
Old 10-24-2014, 02:10 PM   #1
tpdtopcop's Avatar
tpdtopcop is currently offline
Send tpdtopcop:
Default Transom shower pump question?
Hi all,
Bought a new to me 1996 shabah z255 7.4ltr mercruiser and she runs like a dream. I had marina winterize boat two weeks ago and during the winterization they asked me about the transom shower? I said I have never used the shower and dont know if previous owner did either. They called back and said the pump to shower was not working and left it at that, but is that something that I can change and replace? Where is it located?
thanks
Brad
  • Old 10-24-2014, 06:59 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Transom shower pump question?
    On my 1999 Z280 the transom shower pump is screwed to the inside of the transom. Are your sure the marina mechanic had the circuit breaker for the pump turned on?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-25-2014, 11:32 PM   #3
    tpdtopcop's Avatar
    Send tpdtopcop:
    Steve,
    Thanks for response and no I am not sure? Where would the circuit breaker be? The only reason they asked about winterizing it was because the seacock was open? I dont know where that is either by the way.
    Old 10-27-2014, 03:38 PM   #4
    The seacock is located in the bottom of the hull. It's a valve that you can open or close. You can find it very easily by looking underneath your boat and finding the thru-hull fitting where it pulls the water from. It'll either be a brass or a white plastic fitting. The pump should be routed to a switch or breaker somewhere either in the cabin, or near the shower part itself. If it's not, then perhaps it's wired into the fuse panel and the fuse is just blown. It'll require some investigation and wire tracing, but hopefully you can find it this way.
    My suggestion would be to leave the seacock valve open, turn the showerhead on. If no water comes out, then you're probably pretty safe. If you want to make sure you're safer, you can unscrew and remove the fitting where the showerhead fits onto the pump itself, and this should clear the line of any residual water, and then screw the fittings back on tight again. Even though it won't be fully winterized with antifreeze and such, you've got less of a chance of your transom shower system freezing if there's minimal water in the line.
    Old 10-27-2014, 05:25 PM   #5
    lisapaul1 is currently offline
    Send lisapaul1:
    Brad,
    I have a 2000 Z272 Shabah with a Transom shower pump. Mine has an option for fresh water or lake water. If your has that option, you might want to check the fresh water supply as well. Mine is a 5 gallon bag on the starboard aft side. Make sure it's empty and the lines blown out as well.
    Paul
    Transom Shower karmann Original Mariah Talk 1 06-03-2009 02:56 PM
    1995 272 Barchetta Transom Shower karmann Original Mariah Talk 1 05-01-2009 09:07 AM
    transom shower lance Original Mariah Talk 3 03-17-2009 06:56 AM
    Transom shower on my Z255 Jeff Barnett Original Mariah Talk 1 09-06-2007 06:37 AM
    Transom shower moondance100 Original Mariah Talk 4 09-06-2007 06:29 AM
    There are 457 users
