Tach problems
Old 09-17-2014, 02:44 AM   #1
norri is currently offline
My Model: Z212 Limited Edition
My Engine: 5.7 Alpha One
Send norri:
Question Tach problems
I have a 99 Z212 Shabah, had tach serviced by Faria months ago and and now realize tach wont go above 3000 rpms approx., even when speedo says I'm doing over 50 at full throttle. It indicates correct reading at idle tho, anyone have any ideas?
TY
  • Old 09-17-2014, 02:40 PM   #2
    Default Re: Tach problems
    There's a few different things you can try, before sending back to Faria to have them service it again.
    1) when it's running, knock on the glass face and see if it changes. My Z250 gauge would occasionally do something similar, and knocking on it would correct the issue.
    2) if you have access to the back of the gauge, there's a switch behind there for 4-6-8 configuration. This is basically a way to select which engine is hooked to it. Occasionally, the contacts on the switch can get cruddy, and cause it to read erratically. Take a small screwdriver and cycle through 4-6-8 a few times to clean the contacts, and then set it back where it was.
    If these don't help, I'd suggest sending it back to Faria and having them take another look at it.
    Old 09-18-2014, 01:35 AM   #3
    Send norri:
    TY Shabah, I will try the tapping thing soon, I knew about the sw on rear and its set to 8, I have contacted Faria also and await their reply.
    Old 09-22-2014, 01:38 AM   #4
    phillycincykid's Avatar
    phillycincykid is currently offline
    My Year: 1990
    My Model: xlc 2150
    My Engine: 5.7 l mercruiser
    Send phillycincykid:
    ill have to check on my connections too. my tech was reading 3000rpms when i was @ idle yesterday.
    Mariah 1990 XLC 2150 5.7 V8 about halfway rebuilt.
    Compass and Tach problems norri Original Mariah Talk 9 06-10-2014 02:54 AM
    Need some help with the Tach mikesull415 Mercury MerCruiser 2 03-23-2012 10:15 PM
    Having problems with Tach & Speedo rickt48 Original Mariah Talk 9 06-21-2011 02:52 PM
    refurbished Tach jeffryb Original Mariah Talk 2 05-09-2009 05:19 PM
    5.7 L Tach problems jmo Mercury MerCruiser 2 09-22-2008 01:11 AM
    There are 438 users
