Electrical Issue
I have a 1995 Mariah Shaba 210, which I was getting ready to put on the lake last week and during my preparation, I lost all power to my electrical system. no ignition, radio, horn, lights, nothing. I know there are fuses under the dash, and a electrical bar of wiring connections behind the battery on the back of the boat. I also know I have a reset button on the side of the engine. if I have checked all of these functions and still have no power, where do I go next? I am at a loss.
Re: Electrical Issue
Probably 4 times out of 5 the problem is down to a poor connection on the battery cables. Trace each one, take the connections apart, clean & reconnect.
Not sure if my 1996 Z210 Shabah has the same setup as your 95 but I had the same thing happen a few years ago. It was a breaker that had popped. Mine has a breaker panel on the side wall below the drivers counsel which has reset breakers for all the electrical systems.
thanks for your reply. have not had the opportunity to follow up on it as yet but will as soon as I can. thanks again.
| All times are GMT. The time now is 10:28 PM. |
