2 questions, trim tabs and throttle
Old 08-11-2014, 07:13 PM   #1
mrboater is currently offline
My Model: Z225
My Engine: 7.4L Bravo
Send mrboater:
Default 2 questions, trim tabs and throttle
Hello All,
Just a couple quick questions for a Z225.
It has trim tabs - I don't know if they were installed after market or not but there is no way of telling if they're down or up while in the water. I have to count in my head every time - is there an easier way to track these? - they're also installed criss crossed to add insult to injury....
Second question, my throttle is stiff going down but the loose when backing off. To the point that if its rough out there, it will back off the throttle while driving (I like to stand while I drive).
Thanks for everyone who gave feedback on the prop issue, picking up a new 4 blade SS this weekend which I'm told will be a great help for the hole shot.
Thanks!
  • Old 08-11-2014, 07:45 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 2 questions, trim tabs and throttle
    I assume you have hydraulic trim tabs, if so then you can install a Trim Tab Indicator system Trim Tab Indicators to help indicate exactly where the tabs are at all times. The indicator ain't cheap, so most people just start with the tabs all the way retracted and adjust as required. As a matter of fact, my Z280 came with an auto retractor module that fully retracts the trim tabs each time the ignition switch is turned off.
    Depending on your throttle, I believe there is an adjustable drag screw on the underside to prevent the the throttle lever from moving due to shock and vibration.
    mikeyt and badjudgement like this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-12-2014, 08:06 PM   #3
    My Model: Z225
    Send mrboater:
    Thanks HR Steve, much appreciated!
    Old 08-18-2014, 04:15 PM   #4
    My Model: Z225
    Send mrboater:
    Can never find my original post but thanks to everyone who recommended the 4 blade 20" pitch prop. It made a great difference this weekend with the hole shot and while cruising.
    Can't help but wonder, would a 5 blade be any better or help any further? I know there is a "sticky" on this but as always I would much rather hear peoples actual opinions and experiences.
    1994 Z225, 7.4L that runs about 4500 rpm WOT
    Thanks!
    Old 08-18-2014, 11:23 PM   #5
    Thanks!
    Stick with your 4 blade. The 5 blade creates too much drag and is mostly designed for tubing/ski boats.
    Trim switch on throttle Red Rover Original Mariah Talk 30 07-07-2022 10:41 PM
    Trim Tabs Mariah1 Original Mariah Talk 3 05-13-2014 04:52 AM
    Has anyone taken apart their throttle control to fix trim switch? csterner Mercury MerCruiser 7 08-30-2011 06:41 PM
    trim tabs ?????????? boat man2 Original Mariah Talk 6 07-07-2009 12:07 PM
    There are 642 users
