Radio cuts out at higher volumes
Old 08-12-2014, 04:33 PM   #11
Smokymance's Avatar
Smokymance is currently offline
My Model: 182
My Engine: 4.3L MerCruser Alpha 1
Send Smokymance:
Default Re: Radio cuts out at higher volumes
Originally Posted by theeasynine View Post
So crazy mine does this also. I changed both power wires to 14 gauge yesterday and it still cuts out. It's a puzzler.
when you say you changed the two power wires, are you talking about the always hot 12v wire, as well as the 12v on ignition only?
are you running the always hot wire directly to the battery? that was the solution to mine...i didnt replace it, i just sealed it off and tucked it under and ran a separate wire to the battery.
The ignition hot only wire i left stock...that only tells my radio when i got the key on and does not power it for audio.
182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
  • Old 08-12-2014, 04:49 PM   #12
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    Yes I changed key hot and constant. After lunch I'll run a temporary constant hot straight to battery and see if that works.
    Patrick
    Old 08-12-2014, 05:41 PM   #13
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    Thats what i did to try it out initially and it worked...so i ran it behind the panels neatly...
    ran also separate lines directly for the ignition hot and ground to the battery with no success..so i left those stock
    LM
    Old 08-12-2014, 05:48 PM   #14
    Send theeasynine:
    Fixed! Thanks for the help I don't think I would have thought of that. I'll have to fish it back through the side now.
    Patrick
    Old 08-12-2014, 05:57 PM   #15
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    anytime...glad u fixed it...i added a 10A fuse just in case, even though the radio i believe has a built in one...
    Intermitten pop through carb higher rpm crashcourse101 Mercury MerCruiser 16 07-18-2013 07:56 PM
    Has anyone figured out a higher attachment point for diablos 93diabloForme Original Mariah Talk 8 07-08-2013 06:09 PM
    Radio Cuts out bnussbaum Original Mariah Talk 8 09-12-2009 12:09 AM
    4.3L Stalls/Kills at Higher RPMs abillmann Original Mariah Talk 3 08-07-2009 08:05 PM
    Higher RPM's = Engine Sputter Roger Butterfield Mercury MerCruiser 10 06-24-2009 09:09 PM
    Total Threads: 13,324
    There are 417 users
