Fuse Panel access on a 1999 Jubilee 214?
Old 07-13-2014, 11:12 PM   #1
Chuck Bradley is currently offline
My Model: Jubilee 214
My Engine: 5.0 Merc
Send Chuck Bradley:
Default Fuse Panel access on a 1999 Jubilee 214?
Can anyone please give me directions on accessing the fuse panel for a 1999 Jubilee 214? Instructions on gaining access would be much appreciated!
  • Old 07-13-2014, 11:16 PM   #2
    Default Re: Fuse Panel access on a 1999 Jubilee 214?
    First off, welcome aboard! Secondly, there is a search box in the top right corner of the screen. Enter 'fuse panel Jubilee' and you should find what you are looking for.
    Old 07-15-2014, 07:11 PM   #3
    My Engine: 5.0 Merc
    Send Chuck Bradley:
    Thanks for your help and welcoming me aboard mikeyt. Love the 1999 Jubilee 214 I acquired a few weeks ago! It has run like a champ. Just an issue with bilge pump after a long day of play with kids on lake. The automatic pump worked well until the end of the day when I noticed the light on bilge switch did not work. Had hoped it was a simple fuse issue, but upon replacing the fuse, it blew the new fuse as well. Could I ask what in your opinion is the most likey cause and solution? Thanks again for any info you can provide, Chuck B
    Old 07-15-2014, 08:23 PM   #4
    Problem with the bilge is likely a short either in the wiring at the bilge pump or the unit itself. Take the connections apart at the bilge pump & clean/reconnect them to see if it makes a difference. Might be simply time to replace the 15 yr old pump though...
    Old 07-21-2014, 05:54 PM   #5
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    To answer the original question and to help the next guy that's desperately searching for their well hidden fuse blocks on the Jubilee;
    Remove the angled ceiling panel in the Lav. The fuse blocks are mounted right above it. The ceiling panel is held in by 2 screws, one at each side of the panel. Once the screws are out, you can reach in and disconnect the light, then pull the panel out.
    mikeyt and ColoradoDiablo like this.
    Thank you blockp for this useful post!
    mikeyt (07-21-2014)
    Fuse Panel ezgoin45 Original Mariah Talk 6 07-30-2019 03:02 PM
    How do i Access the fuse block CSofbuckeyelake General Maintenance 7 08-04-2017 05:38 AM
    Fuse Panel Layout MichelleJ Introductions 3 07-13-2014 03:12 PM
    2000 Jubilee 244 fuse panel nmweber45 Original Mariah Talk 1 06-23-2012 05:29 PM
    Fuse Panel and Ground Bus locations and info? stereoman405 Original Mariah Talk 0 05-06-2009 04:13 PM
    There are 259 users
