97 Z222 Shabah Speaker Size/ Replacement
Old 07-04-2014, 03:31 AM   #1
Eclipse9719 is currently offline
Send Eclipse9719:
Default 97 Z222 Shabah Speaker Size/ Replacement
Hello Everyone,
I have looked everywhere in the forums for this information but cannot seem to find what I am looking for. I was given the go-ahead to do a stereo system in the Z.... With that being said I measured (speaker surround only) the original speakers currently in the boat and they measure out to be 4.5"... Is this correct? Has anyone installed a larger lets say 5.25 speaker without extensive modification? Any help would be greatly appreciated.
Brandon
  • Old 07-04-2014, 02:07 PM   #2
    Default Re: 97 Z222 Shabah Speaker Size/ Replacement
    Brandon ,
    I am pretty sure the guys have been running 6.5s , but hang in there , there are quite a few members with kick a-- systems in their Mariah that I'm sure will chime in soon.
    Old 07-04-2014, 06:01 PM   #3
    mikesnowman's Avatar
    mikesnowman is currently offline
    My Year: 97
    My Model: 272 Shabah
    My Engine: 7.4 mag
    Send mikesnowman:
    2nd Mariah. Both I had to cut the opening larger
    Old 07-04-2014, 09:19 PM   #4
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    You may get a five and a quarter inch speaker in there the hole is slightly larger than the small speakers that come in the boat however I installed 6 inch Kenwood and had to cut the holes bigger I did it with a jigsaw it was very easy and the $99 Kenwoods sound really really good I must say
    Old 07-04-2014, 09:20 PM   #5
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    I also installed an $89 Kenwood head unit from best buy that sounds good as well with iPod control, front input, usb input and Bluetooth....
    Old 07-05-2014, 04:11 PM   #6
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    Yup 6.5 Memphis Audio and used a dremel tool... Take your time and keep a few extra bits around.
    doaclnr
    99 Z302 8.2 DP
    Old 07-06-2014, 02:06 AM   #7
    mmckenzie6 is currently offline
    My Model: 202 shabah
    My Engine: 5.7 L Bravo I
    Send mmckenzie6:
    I have a '95 202 Shabah. It also had 4.5" speakers, that were partially tucked underneath the cushion that runs down the side.
    Due to the fact that the new 6.5" speakers stuck out a little farther, and the contour of the inner wall turning out; I decided to just leave the 4.5"'s as hole fillers. I moved back to the flat spot immediately adjacent to the rear seat and cut a new hole with a drimmel tool and one of those multipurpose bits like DOACLNR suggested. Very easy. I also installed new wires for the speakers as well, which was also relatively easy.
    New speaker location is clearly visible, (which I prefer) while the original location was practically not visible at all.
    Old 07-07-2014, 03:05 PM   #8
    woodward33's Avatar
    woodward33 is currently offline
    My Model: Z302 Shaban
    My Engine: 502 Bravo III
    Send woodward33:
    On my 2nd Mariah as well. The '00 202 needed to have holes cut larger. As others have said, I used a jigsaw and a lot of patience. Came out great, though.
    The '99 Z302 had existing 6 1/2" speakers, so its been a piece of cake.
    Good luck!
    Old 07-07-2014, 09:53 PM   #9
    Send Eclipse9719:
    Sounds good. Thank you everyone for your input and advice. I really dont want to take the 4.5" route. I will be enlarging the openings. Ill post pics upon completion. Thanks again everyone for the help!
    Old 06-11-2015, 03:41 PM   #10
    Cory's Avatar
    Cory is currently offline
    My Engine: 5.7
    Send Cory:
    I have a 2001 Z212 that currently have 5.25 kickers in and would like to make changes and add 6.5 speakers. My question is this possible with the way side panels are molded and vinyl trim above speaker? If anyone has done this would like any info and pics of 6.5 speakers installed. It would be greatly appreciated.
    1996 z200 Shabah factory speaker size Snoopinrob Original Mariah Talk 3 05-18-2012 03:45 PM
    Z222 Shabah williamfsmith Original Mariah Talk 4 07-29-2011 03:28 AM
    Shabah 180 Bow speaker wiring RPOLS3 Original Mariah Talk 12 06-26-2009 12:10 AM
    Replacement battery for '99 Z222 Shabah? GSlavens Original Mariah Talk 2 06-15-2009 08:38 PM
    There are 449 users
