-   -   Captains call exhaust---- (http://www.mariahownersclub.com/forum/original-mariah-talk/938-captains-call-exhaust.html)
Z210Shabah 04-05-2008 07:56 PM
Hi all!! Haven't been on in awhile and thought I'd ask about captains call exhaust.I would like to put something as close to the original with SS tips to show it off.Any ideas which manufacturer I should go with and price?Thanx-Larry J.
Z 202 04-05-2008 10:17 PM
There was some discussion on retrofitting Captains Call in this thread:
http://www.mariahownersclub.com/foru...hlight=exhaust
WetWilly 04-07-2008 04:11 AM
Hi Z210Shabah,
There are several manufactures of Captain's call also called silent choice exhaust systems, so finding a system that's right for your Shabah should be fairly easy.
Here's a link to Corsa, they're one on the best known,
Here are some retailers from the internet so you can get a idea on the prices. Just click on the numbers:
#1
#2
#3
#4
As for the tips, it is believed this may have been an in house item.
Remember, your not going to see much of a performance gain but you will definitely sound louder if not more wicked!
Good luck,
indykoch 04-07-2008 04:03 PM
Corsa Part Numbers
2 Attachment(s)
Sorry guys, I meant to post this a while back...
For my model (Z212), Corsa was the supplier of the diverters and tips. They sent me the drawings (attached). The whole unit was a "P210SB" and the price was north of $1300 if I remember right. Not quite worth it to me.
The diverter had a nasty offset so the exhaust would exit the boat in the correct place, making it a "rare" piece. Also, the tips are "different" from other boats. So you end up paying out the nose for the look of original.
For those of you able to use a "standard" diverter, but want the rectangular tips, the part number from Corsa is 11514U (70° angle).
GBRONNE 02-10-2009 09:54 PM
Hey Ryan, I Have A 272 2000' Think Its The Same Offset??
Gary
indykoch 02-10-2009 10:31 PM
Sorry Gary, I really don't have any idea. The drawing I attached says "212 Shabah" in the title block, so I would guess they aren't the same. Corsa was very helpful when I originally inquired and I'm sure they'd provide the same for you.
GBRONNE 02-10-2009 10:42 PM
Hey thanks for the fast reply...dam, thats what i figured, ill call corsa tommorow, just found their number, have a good summer. gary.
z275st 02-17-2009 01:04 AM
Re: Captains call exhaust----
Hi GBRONNE,
I have the 2001 Z275 that is built on the same lower hull as yours. There is a pic of the engine and how the exhaust cuts out the back in the gallery in the 2001 boats under "z275st's Shabah z275st" photos. If it would help, I could send you more pics from the sides.
95 Z240 Talari 03-23-2009 02:43 AM
Re: Hey WetWilly
I have a question about one of the Boats that appears on top of the Forum.
Does anyone for sure what year the Navy Blue & Ivory boat is. The guy driving it is wearing a light blue t-shirt!
I'm curious about the thru hull exhaust on it and was wondering if I could exit mine in the same place for my 95 Z 240 Talari?
Mike
WetWilly 03-23-2009 06:13 AM
Re: Hey WetWilly
1 Attachment(s)
Hi Mike, talk about coincidence, I had the same exact same idea quite a while back...
The Mariah your looking at is a 98 Z272 Shabah that was put up on our gallery by ShabahZ250 a long time ago (I attached a picture of the back end of this Z272 so you could see the tips better).
These same tips are too wide to fit in the same location on our Z240's as they fit on this Z272 The tail area on the Z272 is about two inches wider than our Z240s (you and I both have the same model), the area underneath the hull along the transom is tighter on our Z240s and the cockpit cover top stored under the sunpad might get in the way as well.. Another thing to consider is the surface angle of that part of the stern, the Z272's angle is about 70 degrees where ours is much steeper.Perhaps you might be able to find smaller round exhausts and could have the mounting flange altered to fit the angle and with some careful pluming, get them to fit without any clearance issues in the engine bay. If your determined to try to fit those same exhaust tips as shown on this Z272, PM me, I just happen to know where a set of these same NOS tips are and they might be available.
