Changing trailer bulb help !
Old 06-07-2014, 09:44 PM   #11
Default Re: Changing trailer bulb help !
Originally Posted by Paul F View Post
LEDs installed. Still no right turn signal, but they look cool!! Anyone want a set of submersible Wesbar lights?
Double check your ground on that side. Take it apart, file it down & reconnect.
  • Old 06-08-2014, 03:15 AM   #12
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Ground is good at taillight as running lights work.
    Old 06-08-2014, 03:32 AM   #13
    Well you could hook your trailer up to another vehicle connector and see if they work properly. If the lights work then you know the problem is in the wiring before the vehicle connection. My vehicle connection has a habit of corroding a bit so i spray some WD40 into it and using a bit of sandpaper on the end of a screwdriver just work it around a few times in each female connector.
    Old 06-08-2014, 10:07 PM   #14
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    10 amp fuse in truck..... Good thing the LEDs look pretty....
    Old 06-08-2014, 11:33 PM   #15
    Those LED trailer lites are nice & bright for sure!
    Changing outdrive oil jballa24 Volvo Penta 5 10-14-2014 01:29 PM
    Wanted: Bow Navigation Light & Bulb type (1997 Shabah180SE) gnewk51 Mariah Parts For Sale & Wanted 2 12-27-2013 03:34 PM
    Light Bulb Replacement estiven Original Mariah Talk 21 06-11-2011 07:30 AM
    Wanted: docking light bulb lcoen777 Mariah Parts For Sale & Wanted 14 07-09-2009 06:41 AM
    Changing prop! Lars Prop Talk 8 07-04-2008 05:37 PM
    There are 534 users
